changing U bolts only
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ZHUGGER, Feb 10, 2010.
  1. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    IS that * leaf spring U-bolt specific or can I use that for driveshaft U-bolts on U-joints too ??
    Great......
    I just ordered some NAPA U-bolts for my 1350-1310 Conversion U-joint to pinion yoke.....
    DO I really need to 2nd guess this now ??
    BTW Anyone know what the torque specs are for this application ??
    Sorry to hijack.
  2. Skip Fix
    Skip Fix Veteran Member
    2,217
    25
    Mar 21, 2007
    Katy,Texas
  3. retorq
    retorq Veteran Member
    4,921
    May 13, 2003
    Kingman, AZ
    I must be misunderstanding this .... You want to use flat ubolts where rounded is called for??
  4. retorq
    4,921
    May 13, 2003
    Kingman, AZ
    ubolts != ujoints.
  5. BondoSpecial
    8,694
    Sep 20, 2004
    Connecticut
    Yeah, no. The stock u bolts have a nice widened contact area in the "saddle" area of the u bolt. The aftermarket random brand ones I have seen never have this so that puts a smaller surface area in the saddle of the u bolt, up against your axle housing.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Huh ???
    There's 2 kinds of strapping methods for U-joints to a pinion yoke that I saw.
    The brackets, or U-bolts. At least that's what I thought......pretty sure.
  7. protour73
    protour73 Veteran Member Lifetime Gold Member
    6,028
    Sep 21, 2006
    West of Chicago
    no dude, the strap torque values on the u-joints is only like 26 ft lbs. ( and I'd have to check on that) If you over torque these, you will crush the bearing caps in the u-joint. I'll check and post it.
  8. 79camaro2001
    4,783
    May 4, 2003
    Monroeville, PA
    Ace different applications, I bought u-bolts from Napa for the U-joints and had no problems. Currently on the camaro I'm running the strap kit from Napa as they was thicker then the factory and I lost a bolt the last time I pulled the drive shaft out.
  9. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Thanks, that's what I needed to know. Thanks again guys.
  10. retorq
    4,921
    May 13, 2003
    Kingman, AZ
    Yeah we (were) talking about ubolts for holding the rear end to the springs ... I think. lol
