changing U bolts only
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ZHUGGER, Feb 10, 2010.
  1. retorq
    retorq Veteran Member
    4,921
    May 13, 2003
    Kingman, AZ
    I think I see what you mean ... I don't think it really matters. I've seen tubes dented but not with small ubolts, they were big beefy ubolts and std rear end tubes.
  2. ZHUGGER
    ZHUGGER Veteran Member
    637
    Apr 30, 2003
    Guyton,Ga. USA
    Gary, great info on the matter...I don't think mine had washers on my U bolts. :confused: Eaton recommends them..Are Grade 8 strong enough in your opinon? Or what do you recommend????
  3. INSPECTOR57
    INSPECTOR57 Veteran Member Lifetime Gold Member
    491
    25
    Sep 14, 2007
    Stillwater, Oklahoma 74075
    Grade 5 or 8 is OK - you don't need overkill here IMO. GM rarely used grade 8 hardware. I'd try to find washers thicker than standard. Notice it's flat washers & not lock washers.
    Gary
  4. ZHUGGER
    637
    Apr 30, 2003
    Guyton,Ga. USA
    alright, sounds good.....thanks alot!
