Chassis Works Sub Frame Connectors for my 78 LS swap project
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Gasoholic, Mar 8, 2020.
  1. Gasoholic
    Gasoholic Veteran Member
    198
    82
    Apr 2, 2019
    MI
    Just thought I'd throw this out there and see if anyone else has installed a set of these.
    I like the way this set goes together. It looks pretty strong to me.
    This would be for my 78 LS3 swap project.
    http://www.cachassisworks.com/Attachments/DataSheets/59XX_g-Connectors_DS_WEB.pdf
    I'm wondering about exhaust clearance.
    They offer the parts separately and it looks like the sub frame connectors by themselves should fit no problem.
    I'm wondering though about the Cross Connectors, and drive shaft loop.
    I plan to run long tubes and 3 inch collectors.
    I may just pull the trigger and get the sub frame connectors and wait till I get the motor and exhaust set up and then see if it looks like I can fit the cross connectors and loop.
  2. Fbird
    5,355
    1,355
    Feb 12, 2011
    atlanta, ga
    great for open headers.....not thinking you are going to get around that mess...with a set of pipes
  3. lightly-modded
    lightly-modded Member
    71
    34
    Oct 3, 2018
    New Hampshire
    I have their torque arm setup, and plan on running a 3" exhaust. I have only done a quick mock up so far, but the exhaust is going to have to be completely custom made to fit.
