Cheap 1" Nylon Tie Downs
Discussion in 'The BS Topic' started by Jerry Lee W., Aug 9, 2014.
  1. Jerry Lee W.
    Jerry Lee W. New Member
    21
    Nov 7, 2009
    near Tacoma, WA
    I just about put an eye out today trying to secure a load with cheap nylon tie downs. The spring broke right through the pot metal as I was cinching it down. Thank God I had glasses on!
  2. rockheadrocks
    rockheadrocks Veteran Member
    1,383
    Jun 5, 2002
    Woodstock New Brunswick Canada
    I would strongly suggest going to a local heavy truck shop (Peterbilt, Kenworth, Freightliner, etc) and buying 5" ratcheting cargo straps if you regularly haul any kind of loads. Better to have way more load securement capacity than not enough.
  3. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    I only use ratchet straps myself. I never trusted the button straps.
    edit: Glad you are ok.
  4. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    Me too, I never use the cam lock straps any more.
  5. rickcact
    rickcact Veteran Member Lifetime Gold Member
    773
    Jan 16, 2004
    Thompson Ct. USA
    I have used nothing but the cam lock straps. whenever I use them though I use 2 per side. 1 as a backup. The webbing seems way too thin for my liking.
    I had one break a few years ago and almost caused an accident from the load falling off the trailer(scrap steel). After that I have always doubled up.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Yeah those I will only use for something small to stabilize inside my bed.
    I picked up a nice set of Strap On's @ Costco for $20.
  7. ATM
    ATM Veteran Member Lifetime Gold Member
    2,268
    Oct 10, 2009
    Morris, Illinois
    I have never used those. The cheaper ratchet straps are not much better though, the failure rate on those seems pretty high. If I had a trailer I would likely invest in a good set. As it is I can generally get by with ropes using a truckers hitch to secure anything hanging out of my suburban or a pickup truck. I would trust a rope with a truckers hitch way before I would trust a button strap.
  8. rwild1967
    rwild1967 Veteran Member
    251
    Aug 11, 2009
    Look behind you!
    I haul stuff all the time in everything from my half ton on up and I strongly agree with this post!!
  9. Jerry Lee W.
    21
    Nov 7, 2009
    near Tacoma, WA
    I am going to take your advice.
    Thanks! I just wanted to make sure if anybody else has this type of tie down that they use eye protection. I never thought I could be hurt by a tie down, I'm lucky I had my glasses on. Those little chunks of metal peppered my face.
  10. Jerry Lee W.
    21
    Nov 7, 2009
    near Tacoma, WA
    There's a Costco not too far from us, I'll check to see what they have. I'm definitely tossing my bargain tie downs out today, not worth the risk.
