Chevy Avalanche - experience?
Discussion in 'The BS Topic' started by BonzoHansen, Sep 19, 2019.
  1. 72'z'steve
    72'z'steve Veteran Member
    1,202
    239
    Oct 15, 2000
    waukesha wi usa
    The lifters themselves have issues?? that stinks,the 2 fellas at work,the escalade used oil like 500 miles to a quart and the avalanche had crazy driveability issues related to the DOD,The shop did recommend a "camswap" with different lifters,they told me[plus headers,transtune blah blah blah],Maybe they should peddle those things while they still Run!! LOL,Kinda glad I still drive old junk!! Later Steve!!
  2. gramps
    gramps Veteran Member
    1,385
    777
    Jul 5, 2009
    mankato, mn
    What I meant was larger than the ‘02-‘04 years. I think they went bigger again in 08.
  3. Flynt
    Flynt Veteran Member
    834
    13
    Jul 9, 2003
    Alabama, USA
    What is the cause of excessive engine oil consumption?
  4. Knuckle Dragger
    15,587
    1,998
    Nov 2, 2002
    Waddell AZ
  5. gramps
    1,385
    777
    Jul 5, 2009
    mankato, mn
    The short version is the mds or cylinder shut down system. When in v4 (shutdown) mode half the cyls stop firing, and the valves don’t operate so there is no compression. The piston rings then don’t work as they should, so they get filled with the oil from the cyl wall which makes the problem worse as time goes on as the oil “cokes” or gets sludgy so then the rings are full of that crap and thus allowing the oil on the cyl wall to be burnt when the cyl activates again. And they don’t have kind of a junk pcv setup.
    Honda’s are not immune to this, the accords, pilots and minivans with the v6 do the same thing. With the exception they drop an entire bank in that mode - requiring a special computer operated engine mount and sound canceling audio They shake like a mofo, and make a really loud horrendous (think it’s close to the sound we’d make when being mauled by a bear - after reasoning with it fails) so even if you have the radio “off” it’s not really off, it’s playing a frequency opposite to the sound emitted by the engine. Physically unplug the radio in one sometime - it’s deafeningly loud. But anyway same problem they start sucking oil and it just gets worse and worse.
  6. ol' grouch
    ol' grouch Veteran Member
    3,492
    1,086
    Jul 4, 2013
    Evansville, In.
    Toyota, the supposed standard for quality had problems with that on V-6 engines too. There is a small port on the piston skirt that is supposed to do something with excess oil. It gets plugged up and the engines sludge up pretty bad. This is one the higher end Toyota's and the Lexus cars. I don't fool with imports much so I don't remember the details but it got fairly heated between the customers and dealers.
  7. BonzoHansen
    19,954
    1,268
    Jun 1, 2005
    Scott from Hamilton, NJ
  8. Randy 81
    Randy 81 Veteran Member
    934
    20
    Oct 28, 2009
    Loganville, Ga
    Most have already mentioned the things to look for. Plenty of info out there on eliminating the AFM/DOD, so you can solve that issue.
    Since it is the same chassis as the Suburban, parts availability is good for them. I haven't heard anyone complaining about the mid gate setup. I personally would look at the 2500 version, better brakes and 6.0L engine.
  9. BonzoHansen
    19,954
    1,268
    Jun 1, 2005
    2500 with the 8.1 was discontinued in 2006. I'm not interested in that.
    The Cadillac ext version has the 6.0. It seems there are 6.0 Chevys out there, maybe 07-09. I haven't seen one for sale yet
  10. Todd80Z28
    11,827
    414
    Jun 11, 2002
    Northern VA
    Have you looked down this way yet or in the Carolinas? Maybe better corrosion wise underneath...
