Citrus green 1970 z28 restoration thread
Discussion in 'Project Progress' started by Rosster, Oct 25, 2020.
  1. Rosster
    Rosster Veteran Member Gold Member
    639
    329
    Mar 1, 2020
    B079BAED-ADCA-45F8-BF8B-BBBAF84DE633.jpeg EAF9524B-90FA-43FF-9AD5-3F43FC7BB72A.jpeg BE46908F-6947-44B6-8A58-4DE0E0BEFD3B.jpeg CAD8FFA0-9F53-4B0E-B593-E8E5AD29A6CA.jpeg
    After weeks of cold and overcast we got an 80 degree day today. I was finally able spray the eastwood 2k catalyzed hi temp paint today. 1 1/2 cans provided more than enough coverage. After it all cures, I’m onto installing intake, carb, water pump, pulleys, fan clutch, etc
    roadrace2, rwcz28, 1978 Z/28 and 2 others like this.
  2. TommyRS70
    TommyRS70 Veteran Member
    1,403
    231
    Jan 31, 2004
    KY
    Need a fresh air system with the 2k paint?
  3. Rosster
    639
    329
    Mar 1, 2020
    I use ff organic vapor respirator w/ brand new cartridges/prefilters and fan system to move any mist accumulation. No issues. All paint should include a fresh air system or appropriate respirator. For catalyzed paints, they contain isocynates so you need eye protection and zoot suit too. I painted imron alot back in the day so very familiar with ppe and safety precautions for these type of paints.
    TommyRS70 likes this.
  4. Rosster
    639
    329
    Mar 1, 2020
    And the assembly begins!
    6B5637CA-A417-46C4-9C8F-B5DCA6E197FD.jpeg F3054351-0E96-4D21-A48F-8C2E30AC7FEF.jpeg
    Zoomin, Budz, roadrace2 and 4 others like this.
  5. Rosster
    639
    329
    Mar 1, 2020
    A few more parts on. Also tackled rebuilding and restoring the starter. Surprisingly, internals (bushing, brushes, etc) were in perfect shape. Just a bunch of dirt, grease, and grime. Sadly I forgot to take a “before” picture yet again. Once , blasting, painting, and plating was done, it was an easy reassembly. BTW I used eastwoods cast iron paint which went on kinda dark and dried to a perfect, lighter finish that dead on looks like the original unpainted finish.
    DC404297-4BD7-45A6-887F-381A481641F7.jpeg A3539D08-A6FB-4F8A-B68E-EBADC538BA7E.jpeg 5B8E3659-62D2-4417-AB62-837A34652ADA.jpeg A4BD1FAB-2AC4-482C-9A46-1C9B0DFF0902.jpeg
    biendog, roadrace2, rwcz28 and 2 others like this.
  6. COPO
    21,095
    2,616
    What did you use to clean the aluminum valve covers?
  7. Rosster
    639
    329
    Mar 1, 2020
    I had them vapor blasted and then burnished the finned area for a little more shine using a brass brush. Afterwards I reskinned them using ppg dx501 chromic acid treatment. This prevents future oxidation without having to clear coat the pieces. I also did the same to the intake and any other bare aluminum finishes to keep them looking new down the road.
    Zoomin likes this.
  8. COPO
    21,095
    2,616
    Thanks for the reply.
    Rosster likes this.
  9. Rosster
    639
    329
    Mar 1, 2020
    Finally wrapped up the engine portion. Was waiting on the plug wire supports and a wrench to tighten the holley inlet fittings. I primed the engine again, verified oil flow to all rockers, proper oil pressure, and installed the distributor properly clocked.
    The car is manual steering but I Found a quick ratio power steering box and since the car came with a double groove pulley on the crank from the factory, putting together the stuff needed to mount a new PS pump was a cinch. Will store all the manual parts in the event I sell it sometime in the future (doubtful).
    Now In the process of stripping front bumpers and sheetmetal as well as pulling rear end in prep for putting onto a rotisserie I'm supposed to pick up next week.
    91870027-064A-4A4F-B7A5-9F12B4F84E32.jpeg 82C20D7C-394D-47AF-A635-F545D6D0E26A.jpeg F89DD0A6-E11F-4883-B6D2-AF935EFAB3C3.jpeg
    70lt1z28, biendog and rwcz28 like this.
  10. biendog
    biendog Veteran Member
    261
    66
    Oct 8, 2011
    bellville,tx
    Awesome job you are doing Ross,keep up the great work.That camaro is lucky you found and rescued her.
    Rosster likes this.
