Clamshell motor mount removal
Elliott Taylor
205
I know this has been asked on here before, but do any of you guys have a trick to remove the motor mounts from the frame on a 2nd gen camaro?
The 3 bolts that hold the hold to the frame are easily accessible from the top, but very hard to get to from underneath.
I can see them from underneath around where the lower control arm mounts, but how in the world do you get to them? And what type of wrench do you need ?
Thanks
biker
4,849
As Doug says above, remove LCA. I did mine by using u-joint sockets and "custom bent" wrenches, but considering the time, swearing and misery, I should have dropped the LCA.
Elliott Taylor
205
Considering I don't remove the LCA, I "should" theoretically be able to get a socket on these from underneath? How about crows foot?
DougD
515
Bradenton, FL
U-joint will be your friend. Just make sure it's not a floppy one, use a good tight one. And to reinstall, dab a little grease on it to hold the bolt as you put it back up and in.
Elliott Taylor
205
I have plenty of u joints and extensions. Harbor freight has a set of crow feet for like $12, and I think that will help.
31,207
Distributor wrench.
If you want to make installation easier... Use fishing line or craft wire around the bolt threads to pull them up through the frame and put the nuts on top.
You can usually hit them with an impact wrench and they will tighten nicely with no wrench required inside the frame.
Elliott Taylor
205
Wow that's a fantastic idea about the fishing line. Thanks a lot, that will help with re-installation. I want to make sure I can gain access to them from under the car.
TTR230
619
Burlington, Ontario
I remember when the box style reciever hitches first came out and before a lot of cars came pre-drilled and threaded for them, the hitches came with nuts that had a piece of coat hanger brazed to them. That way you could fish the nut into where they had to go, you gave it a blast with an impact and you broke the wire off for a clean install. Worked great, and I have used that idea a bunch of times on finicky chassis fasteners.
I'm having a hard time picturing this situation so I don't know if it applies, maybe on reinstall, but it's a handy idea.
