Clay's 70 Re-Progress Thread
Discussion in 'Project Progress' started by clay's70, Jan 28, 2011.
  1. giggity
    giggity Veteran Member
    1,439
    338
    Mar 18, 2013
    Pearland, texas
    so what did you end up doing to get doors lined up? I tried putting thick paint stir sticks under door. close it, loosen up hinge bolts, get gap looking good by sliding door around, and then tightening up the hinge bolts. i think it moves a little when tightening the hinge bolts, but its off a little again. Im curious how you did yours.
  2. clay's70
    clay's70 Moderator Staff Member Lifetime Gold Member
    2,177
    121
    May 3, 2008
    Chesterfield, VA (Richmond)
    Thanks Phil!!
    xten likes this.
  3. clay's70
    2,177
    121
    May 3, 2008
    Cody, I'm really not sure. My current plan is to mount them under the dash or under the console.
  4. clay's70
    2,177
    121
    May 3, 2008
    I made these blocks out of some vinyl trim I had.
    Put the door bumpers in.
    I left the striker loose, cut a piece of plastic juice jug to go behind the striker washer so
    I would not scratch up the epoxy. As I got the door closer, I tightened up the striker from
    inside the door.
    Added wood shims as needed.
    giggity and bodymanbill like this.
  5. clay's70
    2,177
    121
    May 3, 2008
    Tested out the keyless entry and the express down for the window.
    giggity, thesalboy and John Wright like this.
  6. giggity
    1,439
    338
    Mar 18, 2013
    Pearland, texas
    thanks!! I dont think my doors have bumpers, that must be a later option? Ill probably try to get them aligned soon.
  7. thesalboy
    thesalboy Veteran Member
    496
    229
    Mar 25, 2017
    Los Angeles, CA
    Neat trick!
