Cleaning Fel-Pro VC gaskets?
Discussion in 'Tips 'n' Tricks Topic' started by ChevyReb, Oct 9, 2020.
  1. ChevyReb
    4,331
    213
    Feb 4, 2003
    SC
    Anyone have tips for cleaning oil off of the reusable fel-pro rubber valve cover gaskets to get them ready to go back on?
    They have the groves in them where the oil collects. I'm initially thinking brake cleaner and cotton balls?
    Also need to clean the heads too. Lmk what you guys do for this.
    KingofThings likes this.
  2. Chevyforever
    Chevyforever Veteran Member
    1,094
    424
    Jan 4, 2011
    I use lacquer thinner on a rag for cleaning oily head surfaces.
  3. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,645
    1,060
    Mar 27, 2016
    NY
    Not familiar with the gasket, however, rubber sometimes doesn't like solvents, I use warm water and dawn dish liquid to clean rubber parts
  4. Ihada70Z28B4
    Ihada70Z28B4 Veteran Member
    192
    26
    Oct 4, 2002
    Buffalo,NY,USA
    Yes warm water and dawn is best. A quick wipe with 70% rubbing alcohol is about all you want to use or they will expand. Also spray tack the vc channel, put the gasket in and let it set. Don't use any tack on the block or gasket surface. I routinely take them off and reuse on my 96 LT1.
  5. biker
    biker Veteran Member
    3,556
    1,625
    Dec 7, 2014
    All good suggestions. I just did mine too. Warm soap and water, dry, wipe with rubbing alcohol. Mine have no grooves for them to sit in, so clean is very important.
    They are more of a silicone material, and I haven't had much luck using any gasket tacky stuff on them. That stuff works great for cork though. Clean and dry with proper torque works perfectly.
  6. ChevyReb
    4,331
    213
    Feb 4, 2003
    SC
    Thanks guys, I'll post a pic of the ones I have later.
  7. ChevyReb
    4,331
    213
    Feb 4, 2003
    SC
    Here is a pic of gasket. I was wanting to clean it in the car bmbecause of the red sealer by the studs as the AFR heads have slots cut in them, idk why!? 20201010_105505.jpg
  8. Jodi
    Jodi Veteran Member
    824
    542
    May 22, 2019
    Just clean them with brake clean, it won't hurt it... that's the same gasket I used for my BBC.
    KingofThings, biker and G72Zed like this.
  9. tom3
    tom3 Veteran Member
    13,469
    1,023
    Aug 1, 1999
    ohio
    That big block is a work of art.
    I've been using old school cork gaskets, reuse several times on the machined surface heads and aluminum covers, no seepage at all. No sealer, that sure creates a mess to clean off.
    KingofThings and Jodi like this.
  10. G72Zed
    G72Zed Veteran Member
    2,914
    1,421
    Sep 8, 2015
    Same gasket that I use on my engine and all the race engines, the best.
