ratpatrol71z28 said:What can I do for water spots on my windows?
I use the same products on glass that I do on paint.
I've heard good about this glass restorer.
http://www.autogeek.net/dia-glasswork-restorer.html
it might work on painted surfaces ,BUT i repeat But , it will not work on aluminium, i work @ alcoa and we had to clean stains off some material to be shipped and vinegar did nothing to itDavid79Z28 said:Vinegar might work.
Here is some reading material.
http://www.autogeekonline.net/forum...ypes-water-spots-type-i-type-ii-type-iii.html
David79Z28 said:Chuck,
There has to be something you can put on your paint to make it less porous.
The products I use in rural Texas may not work for you in So Cal.
I'll start a thread at Autogeek.net and see what the members over there say.
muscl car said:i've used meguires ,mothers ,zymol and surf city products and these were their top of the line waxes & polishes all of these resulted in the same water spot formation on my paint
Rich_NEPA said:Not that I am an expert by any stretch, but cutting or amy kind of abrasion. doesn't seem right to me for this issue...you're trying to solve a chemical problem with a mechanical solution...just my thinking, not trying to offend anyone here.
David79Z28 said:I'm thinking more along the lines of a glaze then sealing it in with a wax or sealant.
Since glazes fill, maybe the impurities in the water won't be able to get in the microscopic intentions in the paint.
I use them here and everything washes off my paint with ease.
Chemical Guys, http://www.chemicalguys.com/default.asp , make some awesome products and are in Inglewood. If a solution exists, I bet they know it!!!
I'm presently using their blacklight glaze/ sealer on an orange car and a black truck. I have that topped with a carnauba wax from another manufacturer. Then I use their V7 spray sealant after every wash. Creates one slick finish!!!
Blacklight: http://www.chemicalguys.com/BEST_WAX_FOR_BLACK_CARS_CAR_WAX_BLACK_p/gap_619_16.htm I have used it on lighter colors with no issues. It doesn't have colored fillers like the old colored waxes or Turtle Wax black box.
V7: http://www.chemicalguys.com/HYBRID_V7_Optical_Select_High_Gloss_Spray_Sealant_p/wac_808_16.htm
