Clear coat help
Discussion in 'Body Restoration' started by Fbird, Jun 7, 2021.
  1. Fbird
    5,513
    1,480
    Feb 12, 2011
    atlanta, ga
    2002 f150 truck. The clear coat is peeling pretty bad now. IF i choose to paint this do I need to take it down to the primer or just sand down into the base coat then scuff n shoot?
    Also can I just shoot back with enamel after a primer? Its just my DD truck...but I would expect a decent job if I'm going to bother doing any of this.
  2. simso
    simso Veteran Member
    590
    107
    Jul 10, 1999
    Australia Perth WA
    If you have base coat showing with no clear on top and its gone that chaulky sort of look, then its got to be sanded off until you hit primer
  3. Fbird
    5,513
    1,480
    Feb 12, 2011
    atlanta, ga
    I was afraid of that. MOST of the truck is ok...just everything pointing UP.
  4. Rustbucket350
    Rustbucket350 Veteran Member
    986
    65
    Sep 4, 2013
    Oviedo, Florida
    It's probably peeling off and into the basecoat if it was ever a base/clear job to begin with. Sand it, reprime (tint your primer) paint and clear. If for whatever reason that sounds like too much work then do everything minus the clear and shoot it in a single stage paint.
