Clutch linkage help
Discussion in 'Original Drivetrain Topic' started by Allison Winn, Apr 11, 2021.
  1. Allison Winn
    Allison Winn Member
    89
    12
    Jan 10, 2021
    Trying to answer 2 questions - #1 my cross shaft small parts kit came with 2 felt seals. I've only ever seen 1 used, and it goes at the frame end. Where does the other go? #2 what is the correct return spring for a 70 Z28? I've seen many different kinds listed but who knows what this year really gets? (The long spring, the small spring with the long extender etc)
  2. boltupal
    boltupal Veteran Member
    139
    56
    May 21, 2018
    I put my felts on each end of the cross shaft.
  3. COPO
    20,586
    2,304
    70 Z28 spring looks like this. Felt goes at each end of the cross shaft, otherwise the grease would not stay in the shaft.
  4. Allison Winn
    Allison Winn Member
    89
    12
    Jan 10, 2021
    Well doesn't the stud from the block have a rubber seal?
  5. ronzz572
    2,345
    167
    Feb 8, 2007
    imperial pa
    Yes it should have a seal on the engine side ball. There is only 1 felt seal used on the frame side. Also to be correct the grease fittings were never installed. There should be a red cone shaped cap stuck in the threaded hole .
