Clutch pedal bushing
Discussion in 'Transmission & Driveline Topics' started by 8pack, May 29, 2021.
  1. berg2695
    berg2695 Veteran Member
    560
    207
    Nov 13, 2011
    AUBURN, WA
  2. 8pack
    2,946
    298
    Aug 29, 2007
    Western, MA
    So confused now! A metal bushing is what I was looking for, but isn’t the part number for the Thomson Nyliner bushing an upgraded part from the stock plastic one that goes in the pedal hole?
    The link in my last post?
  3. big gear head
    big gear head Veteran Member
    6,440
    185
    Jul 30, 2001
    Ky.
    Use a Hurst shifter bushing. I drilled the hole in my clutch pedal and the Z bar for Hurst bushings.
    Dave Nelson and 8pack like this.
  4. berg2695
    560
    207
    Nov 13, 2011
    AUBURN, WA
    The Nyliners (2) are used at the pedal pivots (2 for the clutch pedal and 2 for the brake pedal) -the axle that the pedals swing on. It sounds like you are looking for the single bushing that attaches the pushrod to the clutch pedal. That is a different part that I don't know much about.
    8pack likes this.
  5. badazz81z28
    20,970
    1,472
    Alabama
    2 weeks? My last set lasted 35 years....you don’t need anything other than the OE nylon...you’re doing something wrong. Repop issue?
  6. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    3,096
    270
    Jul 31, 2001
    Ft. Lauderdale, FL
    Or some kind of high pressure monster pressure plate
    8pack likes this.
  7. clm69z28
    clm69z28 Veteran Member
    302
    Oct 29, 2011
    encinitas ca
