Clutch recommendations for a 2005 LQ4 Swap
Discussion in 'Transmission & Driveline Topics' started by Jack Deibel, Sep 24, 2021.
  1. camarochevy1970
    camarochevy1970 Veteran Member
    8,057
    184
    Jan 23, 2003
    Pittsburgh, PA
    It's actually very common in the Viper community. Stock dual disk clutches have NGR
  2. MadMatt
    MadMatt Member Gold Member
    86
    9
    Sep 14, 2007
    Montclair, VA
    That actually depends on the design. In multi disc clutches with a floating intermediate plate (the metal disc in between each clutch disc) they will rattle when the clutch is disengaged (not just at idle). This is normal.
  3. badazz81z28
    21,301
    1,540
    Alabama
    I know on the Mcleod, the center plate is not floating and this clutch doesn't make any noise. A floating plate sounds like a bad design.
  4. camarochevy1970
    8,057
    184
    Jan 23, 2003
    Pittsburgh, PA
    My rst made the sound as well. It's not earth shattering, a lot of people probably can't hear it
  5. Jack Deibel
    Jack Deibel Jack
    42
    Jan 15, 2018
    Orchard Park NY
    Slight noise aside, it sounds like you guys with the twins recommend them for a street cruiser standpoint correct?? Easy pedal pressure, smooth 1st gear take offs, etc...
    badazz81z28 likes this.
  6. camarochevy1970
    8,057
    184
    Jan 23, 2003
    Pittsburgh, PA
    yep
  7. biker
    biker Veteran Member
    4,329
    2,137
    Dec 7, 2014
    As for noise, bikes have had multi disc clutches for decades because the increased surface area gives you friction (holding power) needed in a small package and without monster springs. Remember, bike clutches are only squeezed by your fingers.
    Older dry multi disc bike clutches (Harley, Ducati) rattled because that is the nature of them. Wet clutches are damped by oil, no rattle.
