Coilover
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by DBS, Apr 25, 2019.
  1. DBS
    DBS Veteran Member
    366
    14
    Sep 24, 2014
    Belzoni MS
    Just wondering what spring rate yall running on front coilovers? I have 550 pound springs now but I want to improve the ride a little.
  2. badazz81z28
    19,918
    1,210
    Alabama
    I run 650 in the front and 450 in the back. I have LS engine weight in the front.
  3. dcozzi
    dcozzi Veteran Member
    3,952
    1,002
    May 1, 2002
    Phoenix, AZ
    Is your car set up stock or are there aftermarket parts involved?
    I think the stock front coils are like 450 lbs?? Correct???
    550 lb should be stiffer but, if you want better ride quality, you could use a coilover with a progressive spring like Hyperco has.
    https://www.hypercoils.com/dual-rate-springs/
  4. DBS
    DBS Veteran Member
    366
    14
    Sep 24, 2014
    Belzoni MS
    I have SPC upper and lower control arms,viking coilover shocks with 550 pound springs
  5. 79T/Aman
    2,628
    246
    Oct 7, 2004
    Dickson TN.
    The front will not have much affect on the ride quality and if you have the car lowered you MUST have stiffer springs, 550 is fine, adjust your shocks.
    The rear suspension will have much more to do with ride quality.
