Color for 72 camaro underneath
Discussion in 'Body Restoration' started by Carmine, Feb 23, 2018.
  1. Carmine
    Carmine New Member
    Feb 5, 2018
    Looks like red oxide primer. I want to paint factory red. Can anybody tell me where to get it? What color is it? Plumbers torch did the job very well.
  2. steins70z28
    steins70z28 Veteran Member
    285
    44
    Apr 14, 2012
    Tulsa, OK
    Used this product, which can be ordered in red oxide, on my 70 matched my color almost exactly. Good product!
  3. CamarosRus
    CamarosRus Veteran Member
    8,527
    145
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Stein.............I commend YOU for recognizing the Quality and Value of SPI products.
    Steve Nuwer (L16Pilot) did a thorough process of coming up with a formula of mixing
    a small amount of Black into the above Red Oxide SPI Epoxy to get the CORRECT
    shade of 1970 Norwood primer...
    I hope he sees this thread and posts his results as I read them on the YENKO.NET web
    site................
  4. Z27LS3
    Z27LS3 Veteran Member
    840
    Nov 12, 2007
    Pensacola FL
    heres what mine looks like, its original. this was a few years ago car had about 4 or 5 thousand miles when pic was taken.
    http://i1039.photobucket.com/albums/a477/kevin1walsh/72 camaro/DSC_0806 3.jpg
    <a href="http://photobucket.com/" target="_blank"><img src="http://i1039.photobucket.com/albums/a477/kevin1walsh/72 camaro/DSC_0806 3.jpg" border="0" alt="2015 speedo gear new matching trans to 2.73 diff photo DSC_0806 3.jpg"/></a>
  5. CamarosRus
    8,527
    145
    Feb 16, 2000
    Quoted from Steve Newer.......
    "On the subject of the SPI epoxy, I spoke to Barry and have been working with his Epoxy for a couple of years on my 70Z project. Per Barry's advice and based on my own working experience, I get more consistent results in the gloss / flat appearance using the epoxy versus urethanes, whether they be clears or solids. For the black, I used anywhere between 3% and 8% by weight flattener before adding the hardener.
    On a side note, to duplicate the 70 Norwood red oxide,red oxide ep I like 8% black and 5% flattener by weight added to SPI's oxy (pre-hardener). I understand the red oxide appearance could change based on several factors, but based on original no-UV exposure panels I have, the above matches very well.
    READ and SEE Below
    http://www.yenko.net/forum/showthread.php?t=143798&highlight=norwood+oxide
  6. CamarosRus
    8,527
    145
    Feb 16, 2000
    20170903_153149.jpg 20171019_193304.jpg 20171019_193333.jpg imagejpeg_0001002003.jpg output.jpg Underfloor with SPI Epoxy Black ...No Flattner
    Firewallwith PPG Delfleet Essential Polyurethane Single Stage
    mixed to semi gloss
  7. 74BIBELOT
    74BIBELOT Veteran Member
    865
    57
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    A2599B63-9FFB-4A78-B215-79EA56043CB4.png 897A347A-D84C-438E-BE78-AE35AC3D303F.png My original 74 Camaro Norwood red oxide:
  8. secondgenaddict
    secondgenaddict Veteran Member
    365
    148
    Dec 29, 2012
    Upstate South Carolina
    You can get a pantone chip and have it matched - this is a 73 RS LTZ28 cowl under the dum dum...
    PANTONE 490 - matches perfectly - do not worry about what it looks like in this photo - it really looks like this with a flash -
  9. l16pilot
    1,933
    171
    Dec 13, 2004
    Hurlock, MD, USA
    Thanks for the reference Chuck, but just to be clear....the mix I use is based on a single cowl section from a Norwood 72 Camaro where the Red Oxide had not been exposed to any UV light. I cannot say this is correct for all 70-73 Camaros as the ELPO solution aged over time. I'm happy with my results and for anyone wishing the same/similar....
    Using SPI Red Oxide, I add 8% black by weight, then add 5% of the total red+black by weight of SPI's urethane flattener. After that add the activator, thin to your desire and apply.
    McCune likes this.
  10. CamarosRus
    8,527
    145
    Feb 16, 2000
    Steve, I hope YOU know how much I respect your dedication to the restoration process................
    I still dont comprehend how I would replicate your above mix unless I had a gram scale...
    Should I buy a cheap gram scale vs using a visual clear plastic PPG cup marked with oz's
    Can you either type here a scenario of the above in ounces
    or email it to me so I can SEE it and better comprehend
    Thanks for your patience
    (Ya Cant Fix Stupid)
