Complete original 1973 Z28 L82 350 engine
Discussion in 'Swap Meet Section' started by jim farley, Feb 19, 2020.
  1. jim farley
    jim farley New Member
    Feb 18, 2020
    IMG_1511.JPG IMG_1486.JPG I'm offering for your consideration, a COMPLETELY original 350 engine from a 1973 Z28, block serial 3970010, engine suffix code CLK, 4 bolt main, 330550 steel crankshaft, forged flat top pistons, windage tray, 330545 heads 2.02/1.60 valves, screw in studs & guideplates, 3997771 intake manifold, and factory Quadrajet carburetor. $1000 located in PA
    74Z28GC3 likes this.
  2. McCune
    McCune Veteran Member
    1,414
    385
    Aug 22, 2015
    st.george utah
    Oil pan? Egr valve?
  3. bodymanbill
    bodymanbill Veteran Member
    1,762
    1,464
    Feb 1, 2007
    South Park Pa
    Where in Pa are u located?
  4. jim farley
    Feb 18, 2020
    Complete engine from Carb to oil pan. If you look at the photo of the intake and carb- someone blocked off the EGR. Location in PA 17886
  5. laspisa
    laspisa New Member
    15
    Feb 26, 2011
    Kailua, HI
    Is the block serial 3970010 the partial VIN to match to car? I have a 73 z that’s missing the original engine, you never know! My VIN is 1Q87T3N171505. Thanks!
  6. Zclassic
    Zclassic Veteran Member Lifetime Gold Member
    583
    12
    May 28, 2002
    Walnut Hill, Florida
    It appears the date on the head is 4/13/73? What is the date on the block pad? Thanks
  7. McCune
    1,414
    385
    Aug 22, 2015
    st.george utah
    The date on the head is A 13 3 January 13 1973.
    Zclassic likes this.
  8. fdeluca532
    fdeluca532 Member
    99
    Nov 7, 2007
    winthrop harbor,ill
    What is the best you would do on the engine. I could come and pick it up but long way.
  9. wnmech
    wnmech Veteran Member
    1,373
    309
    Jul 20, 2014
    grand prairie tx.
    Doesn’t look like he’s posted since February of 2020
