Compressor fittings
8pack
3,016
Western, MA
What’s the difference between these 2 fittings? Are the matching female specific fittings for each? Why use one or the other?
thanks!
1980RS
5,989
MN
High side and low side. Red I think being high and blue low, could also be called suction and discharge.
xten
4,600
Pittsburgh, Pa.
The one on the left is a regular ("Milton" style) fitting for your typical air tool, DA, impact, etc. The one on the right is a high flow fitting. Those are great for HVLP spray guns and anything else that takes ungodly volume. The high flow ones work great for anything, but using the smaller one can cause problems with high CFM tools. Look at the I.D. and you'll see the high flow one is larger.
Hope this helps Bill.
8pack
3,016
Western, MA
Ah, that makes sense. So no real reason to use the lower flow ones. Been wondering about it for years and was cleaning the garage he finally decided to ask someone!
thanks Phil!
Knuckle Dragger
Mayor of Simpleton
16,723
Waddell AZ
Learn something new everyday. I always just went with what the shop was set up for.
Phil G
928
Tucker, GA, USA
I spent 5 years as a Sales Engineer dealing heavily with hydraulics and pneumatics. The one on the left we referred to as "Industry Interchangeable" . The other one we dealt with was "Aro" which is proprietary. Shops typically standardized on one or the other, with the majority going with the "II" version. This was back in the '80s so no HVLP guns at that time.
Fbird
6,210
atlanta, ga
As stated ^^^ standard LONG .(there is also a standard SHORT).... high flow.....There are freaking 100's of different "fittings" out there. Given I travel sometimes to very "remote" places in the world to do field repair work...we have a few tools REQUIRED for certain jobs. We also have the "BOX-O-FITTINS" ...we carry with us also as it never fails...we are in country XXXX and need the 1" drive impact....chit don't fit..the magic box has nothing either? :eek:....been more than 1 time that we've just cut their hose and put in our fitting...then when done..put in a plug ;)
