cooling fan not in shroud
Discussion in '1970 - 1973 Specific' started by Bills69, Oct 18, 2020.
  1. Bills69
    Bills69 Veteran Member
    193
    14
    May 28, 2018
    72 ss no AC replaced water pump with exact pump , did not have a shroud put one in , has a clutch fan (not original) fan is not in shroud .
    What should I look for to have fan correctly positioned in shroud ?
    is original fan and spacer longer than clutch fan?
    the shroud is a used oem are they a little different 70-73 ?
    all belts align so I feel it is correct water pump ?
  2. Twisted_Metal
    28,305
    1,692
    About half of the fan is outside the shroud in the factory position.
    This is how it sits on my 80.
    (SBC V8 with fan clutch and A/C.)
    The position should be about the same whether it has A/C or not.
    The primary difference is the width of the radiator.
    Zstar likes this.
  3. Gary S
    23,441
    1,298
    There aren't a lot of different water pumps available. There is a short pump for 60s and earlier cars and a long pump for 70s and later pumps. If the belts fit, I agree that you likely have the correct pump.
    Fans and spacers are a different story. There are lots of different ones available. You want something that sits the fan about half way into the shroud for best cooling.
  4. Bills69
    193
    14
    May 28, 2018
    I am trying to determine why mine is not
    it is original block
    is the original fan and spacer longer than a clutch fan ?
    do shrouds differ in depth from eng to radiator ?
  5. Adams
    Adams Veteran Member Lifetime Gold Member
    902
    15
    Jul 16, 1999
    From Motown (still in the blood), live in Houston
    Is it a big block car? Post a pic of the spacer that is in between the pulley and the fan. My guess is this is the difference. There are also two different BBC shrouds. Do you have the correct one?
  6. Bills69
    193
    14
    May 28, 2018
    it is a 72 small block 350 with original block
    had no shroud and a clutch fan
  7. Bills69
    193
    14
    May 28, 2018
    can someone with an original fan measure from water pump out to fan
    my thinking is the clutch fan depth is the issue
    thanks
