Correct color for rear axle bump stops
Discussion in 'Original Drivetrain Topic' started by donaz, May 31, 2009.
  1. donaz
    donaz Veteran Member
    181
    Mar 2, 2006
    Scottsdale AZ
    did the brackets for the rear axle snubbers get painted red primer with the body or were they added during assembly and have a semi gloss black finish?
  2. 70 SS/L78
    2,900
    139
    May 5, 2005
    Rockford, MN
    The body was just a shell and it was dipped in primer. They were added during the assembly process. I seem to think it was some other type of coating.... like zinc phosphate but i'm not sure on this, just making an educated guess.
  3. CamarosRus
    CamarosRus Veteran Member
    8,546
    148
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Painted Semi-Gloss black..........ala Rustoleum 7777 or Krylon 1613......or better yet a catalized single stage pro paint from a gun
  4. dkatap
    dkatap Veteran Member Lifetime Gold Member
    313
    Oct 23, 2001
    Central IL
    I believe the brackets were bolted on the body before it was dipped in red oxide on Norwood cars. Brackets should be red oxide with body color overspray on them. Rubber was installed later. Not certain about LA cars.
    Dennis
  5. CamarosRus
    8,546
    148
    Feb 16, 2000
    Dennis, Thanks for correcting me. Below is picture of Jack's survivor Norwood 70 Z. I believe you can see where factory undercoat is on top of factory red oxide. On Jacks car it is hard to see where H.O. overspray is on top of Red Oxide primer........
    Also pic of Phil Borris's 70 COPO Z (Norwood) restored..........
  6. 70COPO
    70COPO Moderator Lifetime Gold Member
    1,099
    33
    Dec 28, 2003
    Chillicothe Ohio
    Picture above was before I located the NOS Muffler..:bowtie:
  7. CamarosRus
    8,546
    148
    Feb 16, 2000
    Phil, Why is your bump stop metal bracket and rubber, different than Jack Seymours and my Norwood 70 Z. Both cars 1970 Norwood !!!!!!!!!!
  8. 70 SS/L78
    2,900
    139
    May 5, 2005
    Rockford, MN
    I noticed that also.... Looks like Phil's version would be easier to install on the assembly line?
  9. M21RSZ28
    M21RSZ28 Veteran Member
    548
    Mar 9, 2006
    1970 1st Design Rear Spring Bumper And Bracket
    1970 1ST DESIGN REAR SPRING BUMPER AND BRACKET
    3980939 - BRACKET (press in type bumper)
    3980937 - BUMPER (press in type)
    1971 2nd DESIGN REAR SPRING BUMPER AND BRACKET
    480718 - BRACKET (bolt on style bumper)
    480717 - BUMPER (bumper w/ stud - bolt on style)
    1970 ASSEMBLY MANUAL SHOWS THE “937” BUMPER AND “939” BRACKET REVISED TO “480718” BRACKET AND “480717” BUMPER
    WITH A REVISION DATE OF 3-12-70 - THIS REVISION DATE IS A PAPER DATE CHANGE ONLY
    1970 CHEVROLET PARTS HISTORY CATALOG SHOWS THE 3980939 BRACKET AND 3980937 BUMPER DISCONTINUED 3-70
    HOWEVER THE CHANGE FROM 1ST DESIGN PRESS IN BUMPER TO 2ND DESIGN BOLT ON BUMPER DID NOT OCCUR UNTIL LATE
    IN ASSEMBLY LINE PRODUCTION FOR THE 1970 MODEL YEAR
    MY 1970 CAMARO BUILT IN VAN NUYS ON JUNE 11 1970 HAS THE 1ST DESIGN BRACKET AND BUMPER
    NOTE THE BRACKET IS PAINTED THE STANDARD GM BLACK USED ON AL GM BRACKETS
    1971 CAMARO ASSEMBLY MANUALS SHOW THE 2ND DESIGN BRACKET AND BUMPER
    M21RSZ28
  10. CamarosRus
    8,546
    148
    Feb 16, 2000
    M21RSZ28, I knew you'd have a 2nd design answer......................
    I have to check my BOXES of stuff, but I'm fairly certain that my 07E (last week of 70 production) Norwood Z has the FIRST DESIGN...........
    Very interesting how we are just NOW noticing so many 2nd design parts.
    Most of this is due to M21RSZ28's insight.................
