Working on a '70 Z28 with a completely stock LT1 down to the exhaust manifolds and solid cam. At some point in the past the original turbo 400 was rebuilt and a rebuilder special 12" convertor was installed. Stall speed is a lousy 1200rpm. Any of you have actual experience with this or know the stock convertor stall speed or spec.? Source for replacement? Thinking of hitting the aftermarket for a quality 11" specd to 2200 - 2300 stall. Thoughts? thanks, Steve weim55 Colorado
The original T.C. was 6 Bolts to Flex Plate. IF you still have OEM Flex Plate will that be a problem. I'm no expert but I'm thinking same coded trans and converter were in LS6 Chevelles (???) You might posting your question at Yenko.net OR I may just fwd your post to LS6 GURU Rick Nelson.....
Wow, THAT'S one I've never heard before! Never even seen a 6 bolt converter in anything other than big trucks. i'll take a look at the flywheel to see if there's evidence. Thanks, Anymore information anyone? Steve weim55 Colorado
That's great information. Thanks for the link to that. That original converter is going to be one needle in a haystack. Set up just for that one year only LT1 likely. If any of you has done an aftermarket converter for a stock LT1, be great to hear your thoughts. It,s critical to get the car to perform as it should.
Check that thing out?! It is welded externally for additional reinforcement plus the 3 additional lugs to secure the convertor to the flexplate! That's a stout factory piece! Thanks very much for taking the time to take and post those pics. This is the stuff that makes sites like this so valuable. Any chance you want to sell that to go back into an original Z28? Steve weim55 Colorado
