CPP COIlOvers
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 89rodknocker, Oct 14, 2020.
  1. 89rodknocker
    89rodknocker Veteran Member
    607
    Apr 10, 2008
    Fremont, Ca.
    I have a 73 bbc full weight car looking at either installing my moroso front drag springs or buying these coilovers. Anybody have experience with these coilovers.
    only reason I'm looking at the coil overs is the installation cost or buying the tool bring me close to the coil over price. Car is a street strip car more street than strip.
    https://www.ebay.com/itm/70-81-Chev...816033?hash=item41d5addee1:g:~LwAAOSwz~paII9A
  2. badazz81z28
    20,548
    1,380
    Alabama
    You might be able to answer your own question. Why do you want to use a coil over?
    I don’t see anything wrong with them
    Rene Melten likes this.
  3. Fbird
    5,529
    1,494
    Feb 12, 2011
    atlanta, ga
    would assume you already have aftermarket lca's ? Also misleading description as adjusting the spring collar is NOT going to change the spring RATE (ie no attached top plate), although 550 should be good.
  4. CorkyE
    11,280
    863
    Unless you're going hard core road, autocross, slalom, etc, or have money to burn, stick with the standard spring setup. If you don't already have them, tubular uppers are a wise choice.
  5. BonzoHansen
    20,715
    1,791
    Jun 1, 2005
    Scott from Hamilton, NJ
    I would shop somewhere with better customer service.
    And the first question to be asked will be why/what are you trying to accomplish.
  6. GoldenOne7710
    5,534
    819
    Jun 23, 2004
    Athens, GA
    A lot of CPP items are rebadged from various manufacturers. Compare their part numbers with other brands and you can figure out fairly quickly who makes the products you want. I got my front and rear sway bars from CPP and received Addco bars...which I was totally OK with.
  7. badazz81z28
    20,548
    1,380
    Alabama
    def nothing wrong with CPP parts. I actually thought the quality vs price is pretty good. I would run their stuff before some other people’s stuff.
  8. bigkat_83
    bigkat_83 Member
    36
    9
    Dec 7, 2014
    Bogart ga
    They are Viking shocks and that's a great price.
  9. nobreaks254
    nobreaks254 Veteran Member
    518
    13
    Jul 14, 2007
    aberdeen, SD
    I bought the same set up from cpp only for a 63 impala. And yes they are viking shocks and I don't see any issues with the quality
