Cracking paint on sheetrock.
Discussion in 'The BS Topic' started by FatnLow, Mar 22, 2012.
  1. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    Any tips? My house is almost 50 years old. My bathroom redo I've found the paint is cracking in several areas. When I moved in there was wallpaper. I stripped it off. Scarping and washing with soap and water. I then gave it a coat of semigloss. New wife didn't like it an we gave it a coat of killz to help in coverage. Now in several areas it is cracking. I know with cars you have to remove it all. Is it the same with sheetrock? Any tips appreciated. Thanks.
  2. twozs
    twozs Veteran Member
    8,817
    172
    Aug 5, 1999
    hopewell jct ny
    is it sheetrock or plaster ?
  3. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    Sheetrock. 2/3 paster wall tile and sheetrock on top.
  4. twozs
    8,817
    172
    Aug 5, 1999
    hopewell jct ny
    sonds pretty thick . that could be an issue
  5. krabben1
    8,245
    74
    May 16, 2007
    ( . Y . )Delco
    Moisture problems?Is there a working ventfan(that is used!)everytime someone gets a shower?
  6. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    Krabben that is on my list of upgrades.
  7. leafs_11
    leafs_11 BANNED
    586
    Jun 24, 2009
    that house being that old ill bet any money that first coat of paint was latex over oil which wont stick.there is a special kiltz just for changing to latex. and going over with 120 grit doesnt hurt either.that layer of kiltz wont help as you had a layer under it.try a razor scraper and take all the paint off and try again.and as stated by someone else the exhaust fan is a must.
  8. chevyJeff1
    chevyJeff1 Veteran Member
    779
    64
    Nov 2, 2002
    Shenandoah VA. Listening to the blues
    This.... Im a paint contractor and I approve this message...:cool:
  9. 73Camaro383
    73Camaro383 Veteran Member Lifetime Gold Member
    2,288
    Oct 29, 2010
    texas
    Your supposed to use oil based paint over the wall paper residue or that will happen.
  10. Twisted_Metal
    29,283
    2,254
    Or... Is it only cracking at the sheetrock seams.
    You may have a little foundation shift (settling) occuring.
