CRAP! stripped bolt hole in cyl head for intake manifold bolts
Discussion in 'Engine Topic' started by need-for-speed, Mar 4, 2017.
  1. need-for-speed
    need-for-speed Veteran Member
    719
    12
    Feb 7, 2003
    Conroe, TX
    Two of the holes for the intake manifold bolts are stripped !! :smash:
    SBC Edelbrock heads. I'm assuming (hoping praying) that I can repair them with helicoil ot Timesert. Based on the configuration/location of these tapped holes I don't see a need to remove the heads to repair. Just the intake manifold. Can anyone advise please?
  2. slayer021175666
    slayer021175666 Veteran Member
    1,320
    79
    Feb 29, 2016
    Idaho
    Maybe someone will have a better idea but....
    I would leave the manifold on for the helicoil work. It will keep poo out of the lifter valley and it will guide your bit angle better. Try not to go all the way through the head. That too will drop poo into the engine.
  3. Twisted_Metal
    28,775
    1,988
    If the heads are built like stock...The bolts go through the head and into the lifter valley.
    They aren't blind holes. (Which is why oil seeps up through them sometimes.)
    You will need to repair them with the intake off just to clean up afterwards.
    Grease on the bit and tap helps catch much of the glitter.
    Good Luck!
  4. Green hornet
    Green hornet Veteran Member
    1,956
    439
    Oct 11, 2015
    North Bay, CA
    I would repair them with the intake off that way you make sure no debris is left behind. Put a rag in the valley to catch as much debris as possible.
  5. Mike N
    2,943
    653
    Jan 13, 2002
    Spencerport, NY.
    Which hole or holes are stripped? I think only the middle two holes on either side are pass thru holes, the ends are blind holes. You can verify this by using a small pick or screwdriver and see how far it goes into the hole.
    Blind hole- leave the intake on but be sure to use a bottoming tap to cut far enough down for the helicoil.
    Pass thru- pull the intake.
  6. 70-camaro
    70-camaro Veteran Member
    3,162
    1,406
    Mar 25, 2010
    marietta ohio
    Run the shop vac as you drill also.
    Edem_Alive likes this.
  7. slayer021175666
    1,320
    79
    Feb 29, 2016
    Idaho
    Ya. Sorry for assuming. I just thought for sure you meant the ends holes. You couldn't even get a drill in the center holes with the manifold installed. It is the center holes that pass through. The end holes are blind. No problem drilling the end holes if the Eddys are like stock. Go check out some pictures of your exact heads on the net to make sure! :)
  8. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Ditto, not worth dicking around, intake off and if you are worried the drill won't follow the hole perfect,
    put a long bolt in the next hole as a visual aid.
    Good luck.
  9. Dave Nelson
    Dave Nelson Veteran Member
    5,071
    3,973
    Dec 19, 2003
    Vineland N.J USA
    This is the way.
  10. rocket dawg
    rocket dawg Veteran Member
    392
    46
    May 5, 2015
    Grand Rapids Mi
    SBC Edelbrock heads? As in aluminum? better read up on tapping aluminum, you could easily strip out the hole with the tap as aluminum tends to plug up the threads. If they are cast iron, not so much to worry about. If you do mess them up, remove the head, send it out to be repaired ( aluminum heads can be repaired )
