Crate Engines (low 400hp range)
Discussion in 'High Performance Modifications' started by cgibsong002, Jun 10, 2011.
  1. cgibsong002
    cgibsong002 Veteran Member
    456
    Jun 29, 2010
    Houston, TX
    Hey guys. Finally saved up enough money and am looking to drop in a new motor. I'm looking for a crate motor for around $3000. I'm hoping to break into the 400 HP range. Do any of you guys know some good sellers? I'm not looking at the standard GMPP, Blueprint, etc. I'm looking for sellers who are building their own engines as I'm hoping to strike up a deal/barter for the engine.
    Thanks!
  2. TX78Z28
    TX78Z28 Veteran Member
    312
    Mar 29, 2006
    Dallas, TX
    Year One has a 400hp motor for like 2999?
  3. mjoc
    mjoc Veteran Member
    3,528
    Apr 29, 2003
    Sherman Oaks, Ca
    what do you have to trade or barter I have a friend who has a few motors for sale. a few 383's a couple of 350's or he can build you a custom unit.
    Michael
  4. cgibsong002
    456
    Jun 29, 2010
    Houston, TX
    I guess I should ask the experts since I have the chance... Would around 400 hp get me in the low 13's and possibly 12's with new tires and other upgrades? Its a 3 speed auto, new 3.76 posi, most likely patriot headers and will have a pypes xchange system.
    Also, what else will I need with the engine? Is a new carb immediately necessary? Its got one of those Holley remanufactured quadrajets. What else? Water pump? I'm just learning about engines so I don't really know exactly what I need here.
  5. Tirefryer
    Tirefryer Veteran Member
    208
    Jul 18, 2010
    Howell, NJ
    you will need a 3k stall converter, sticky tires, and a holley 750dp. With 400hp that should get you low 13's high 12's depending on the weight of your car.
  6. cgibsong002
    456
    Jun 29, 2010
    Houston, TX
    Yeah I know I'll need stickies and other things to get near 12's, but I'll worry about that later when I'm actually racing and have more money. But lets talk about what I NEED to get the new motor in. What's that stall converter? Is that and the carb both necessities? Anything else?
  7. cgibsong002
    456
    Jun 29, 2010
    Houston, TX
    Ah, forgot to mention.. This is just an occasional driver and I've never raced before. I'd like to learn to race once its done but its basically just a street car.
    edit: sorry for the double post.
    I've been doing a lot of reading tonight and it seems many people advise against the ebay and other smaller places. Makes sense.. get something with a good warranty. From what I've seen, I've got three good options that I've found: ATK engines, the Year One mentioned above, and maybe the 383 with aluminum heads from summit or jegs. ATK seems pretty nice. Only thing is there seems to be a gap between the 350HP $2500 motor and the more expensive $3500+ motors. Wonder if he could do something in the middle. What do you guys think?
