Crate motor recommendations needed
Discussion in 'Engine Topic' started by maddart, Apr 29, 2015.
  1. maddart
    maddart Veteran Member
    182
    Feb 10, 2013
    Homer Glen Illinois
    I want to get a crate motor for a 79Z28 and would like some recommendations. I have a budget of 4k and have looked at companies like blueprint, year one, and phoenix engines. Have read good and bad with all of these. Looking for 400hp/400ftlb , i also have a company called AES in elk grove IL local to me that also sells a crate. Does anyone have any input on this. I side toward a vortec engine with roller cam/rockers.
  2. trott
    trott New Member
    23
    Nov 8, 2013
    michigan
    I purchased a crate motor from a place called Tri Star engines out of Wisconsin. so far very happy with it.
    http://www.tristarengines.com/
  3. Devildog
    Devildog Veteran Member
    496
    Mar 22, 2002
    Doylestown PA
    A buddy of mine recently got a 350-375HP crate motor from Summit for his 67 Camaro. Looks like a real nice piece with aluminum heads and a roller cam. He paid under $4k and Summit also offered free shipping too.
  4. Chris71RS
    Chris71RS Veteran Member
    491
    Feb 26, 2006
    An Island called "long" in the north atlantic
  5. trott
    trott New Member
    23
    Nov 8, 2013
    michigan
    Here's the dyno sheet from my Tri Star motor. I added a few extra's on it so I was a little over my budget.
    [​IMG]IMG_1525 by r2010ssphil, on Flickr
  6. 76z28
    76z28 Veteran Member
    2,376
    177
    Jun 29, 2009
    bakersfield
  7. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,895
    606
    Aug 11, 2010
    erie, PA
    WHEN I buy a crate engine it'll be a Blueprint from Summit or Jegs
  8. owen1980
    owen1980 Veteran Member
    429
    Jun 23, 2004
    Brownsburg, IN
    If I did not have money wrapped up in the machine work and kit on my engine I would have gone this route. They send you the dyno sheet with the motor to prove it hit 400HP I have not seen a better deal on paper.
  9. ssenay72
    ssenay72 Veteran Member
    134
    Sep 21, 2012
    Leominster, MA
    I have a zz383 gm motor which was " ok " I guess. But noticed a lot of valve train noise and come to find out that's common on these. Seems like more complaints about the zz383 motor are coming up lately so I would steer clear of that one. I do have a 427 from whites performance in my 81 Camaro that has been good so far. Although that was way more money.
  10. 70ZFORME
    70ZFORME New Member
    17
    Jul 25, 2013
    Northern Kentucky
    Blueprint 383
    I have been building cars and motors all my life. The original 350 in my car was just about wore out. It had been rebuilt twice and the only thing that remained was the original crank turned 30 under and the pink rods. Smoked like a train and it was already punched 30 over. 180K hard miles. I was doing a restomod so I bought a Blueprint 383 last month thinking for the price 440hp sounded awesome and easy too. Today with 300 miles on the new motor i heard the awful bottom end rattle when approaching a stop sign. Went straight home and drained the oil and I have never seen anything like it. It has so much metal in it that it is silver. I haven't contacted blueprint yet but it is only a month old and should be under warranty. I am sick, I followed their instruction to the tee and even used 15w40 oil that they recommended. 300 babied miles never above (3500 rpm) and I have 8lbs of oil pressure and I have changed the oil 3 times. Intial break in was fine, oil was clean. First 300 miles were great, and the engine started to come alive at around 2800. I was excited and couldn't wait to let loose. According to there manual after 500 miles you can change the oil and let her eat. I changed it today and it is toast. I have a hard time recommend them at this time. But maybe it was a fluke. Ill let you know how the warranty claim goes.
