Cut my oil filter
Discussion in 'Engine Topic' started by ChevyReb, Nov 17, 2020.
  1. Jodi
    Jodi Veteran Member
    726
    425
    May 22, 2019
    This is what I use.
  2. muscl car
    23,059
    1,555
    Jul 8, 2001
    SoCal High Desert
    You don't need to cut open a filter when using those Moroso oil filter screens
  3. sandlapper
    sandlapper Veteran Member
    502
    161
    Oct 9, 2020
    SE CSA
    I see the oil filter. Seems the pipe wrench is being used an oil filter wrench.
    I don't have a pic handy, but there are many "tail-pipe / muffler cutters that are essential a chain wrench as above, but also having with a row of cutter blades
    here ya go, see the chain's rollers are actually cutter wheels. But seems the chain wrench above has standard links that grab pipe. JMO The pressure required to cut may simply crush a thinner oil filter's wall; maybe not
    https://www.amazon.com/GEARWRENCH-2031DD-Exhaust-Tailpipe-Cutter/dp/B000M93OUM
    see Jodi's chain wrench exhaust pipe cutter ... it has cutter rollers
  4. COPO
    20,120
    2,021
    This is the one I bought, Proform 66490 Oil Filter Cutter.
    Works on both my Wix and John Deere filters.
    B74AA3E0-58EA-4239-9541-AD03D016126B.jpeg 65F32717-297D-4AAD-955E-CE2F6663EF9E.jpeg
    Added washer to center the blade and wobble.
  5. krabben1
    8,243
    71
    May 16, 2007
    ( . Y . )Delco
    I got the jegs version.Think its about 41 bucks.
  6. krabben1
    8,243
    71
    May 16, 2007
    ( . Y . )Delco
    Thats not going to show you bearing material,cutting the filter open does.
  7. biker
    biker Veteran Member
    2,893
    1,181
    Dec 7, 2014
  8. ChevyReb
    4,095
    109
    Feb 4, 2003
    SC
    I used a hammer and a chizzle because the darn K&N top metal was too thick for my sheet metal players to cut. So I did get some of that in there. Only thing I could find in the folds of filter was one or two very fine metal shavings and some chevy orange paint flecks. Hope I'm good to go. I saw nothing in the drained oil.
    I've never seen the filter screens before thanks Chuck. Also I
    Will be buying screen and buying or making a tool to open filters for next oil change. I appreciate all of the information everyone has provided so far!
  9. COPO
    20,120
    2,021
    Garage is my kitchen.
