For those of you with LS1/t-56 swaps and t-56 trans only swaps, who had to cut up the floor/trans tunnel and who didn't? Please list wether you've used things that influenced the need to cut or not like body bushings, engine placement, etc.
I did just the trans swap in my 78Z. The transmission is longer than a Muncie and T-10 so making a hole is guaranteed! I also had to cut a little more on the driver side so the tunnel cleared the reverse light pigtale. Your going to cut...whats your concern?
I'm not concerned really and I'm prepared to cut. I've just heard some didn't and was wondering what they may have done differently
I can't remember exactly who but I'm sure some said they didn't. I thought maybe they would chime in...if they're out there.
I didn't have to cut more than a shifter hole. I am not using the reverse lockout solenoid though. I made my own trans cross member. I have the subframe body mount eliminators as well.
What mounts/pan did you use? I was just on Todd80Z28's website and he also only listed cutting a shifter hole.
I had to cut the shifter hole longer (towards the rear) to clear the shifter. Mine was an original 4 speed car. Used stock engine mounts and ATS trans cross member. No other cutting (or hammering) required.
