jamieg285
I've reached a stage where I'm ready to cut/fit my rear quarter skin. So far I've lined up the skin and marked it's outer edges. These are Tabco skins, that are bigger than the usual skins you see.
The metal gauge on these is thicker than the more common skins too, and is similar thickness to the original metal, so retaining original metal for strength isn't a consideration.
In the pictures the green/blue lines are marked on the panel to indicate the edges of the skin - the maximum I can cut out. I'm pondering whether I need to cut that far, especially on the B pillar and am wondering whether to cut lower - either in a straight line level with the bottom of the window (red line), or perhaps a diagonal(orange line) to reduce the amount cut out even more.
Around the window I'm aiming to use as much of the new panel as possible, but keeping below the edge.
At the rear, the skin actually goes past the trunk edge, but I'm intending to cut 1 inch away from the edge to retain the original fold.
What would you do?
What would you do?
