Cylinder head advice
Discussion in 'High Performance Modifications' started by gs462, Jan 19, 2010.
  1. gs462
    gs462 Veteran Member
    189
    Oct 3, 2009
    chardon ohio
  2. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    What heads?
    please post up the name of the company selling them as well as the part number of the head in question.
    pdq67
  3. gs462
    189
    Oct 3, 2009
    chardon ohio
    posted,.
  4. mrdragster1970
    7,821
    507
    Apr 12, 2007
    PROCOMP CYLINDER HEAD DYNO TEST.
    PRO COMP as cast 180cc, and cnc'd 210cc (worst)
    used Stock GM vortec 1 ton p/u truck heads 30hp gain (good)
    Brodix IK 180 as cast, 35hp gain over the vortec (very good)
    AFR 195 eliminators, 37hp gain over the IK 180's (Best)
  5. gs462
    189
    Oct 3, 2009
    chardon ohio
    Great thanks for the info is it posted somewhere?
  6. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    they arnt bad if you only have 650 bucks to spend on alum. heads. try skip white from whites performance if you want a pair, if you have 1400 buy the afr 195's, but if your just a guy with a low budget they will work for a 400 hp sbc.
  7. chevyseve71
    chevyseve71 BANNED
    232
    Jun 15, 2009
    MWC,OK
    someone explain to me how you say ALUMINUM $1000+ heads can only support 500 HP. when you see people running FACTORY heads (ported out the ass im sure) and pushing 700 HP+++ at my local drag strip and everywhere else. enlighten me
  8. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    Just looked again, I figure they are offered by Midwest Motorsports.
    And probably the same head Skip White is selling so please check him too.
    pdq67
  9. gs462
    189
    Oct 3, 2009
    chardon ohio
    Skip White makes them sound like they're pretty good for the money, for a budget 400 hp sbc.
  10. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Found that in an article somewhere.
    They used a basic 355" Chevy, and used the same short block for all the dyno pulls.
    No changes were made except heads.
