Damn ash tray keeps sliding out
Discussion in 'Interior Restoration' started by hutchenc, Oct 1, 2011.
  1. hutchenc
    hutchenc Veteran Member
    345
    Aug 21, 2007
    Wyoming/Colorado
    My ash tray will not stay put and it's driving me nuts. What can I do to keep it from sliding out so often (other than the obvious McGuyver fix)?
  2. 73Camaro383
    73Camaro383 Veteran Member Lifetime Gold Member
    2,288
    Oct 29, 2010
    texas
    I pulled it and put some hard stick on side molding(thin kind) to make it much stiffer..
  3. hutchenc
    345
    Aug 21, 2007
    Wyoming/Colorado
    What kind of side molding?
  4. 3SLO5
    3SLO5 Veteran Member Lifetime Gold Member
    3,639
    Jan 7, 2001
    Edison NJ USA
    just take out the 4 screws that hold in the metal slider. now bend the tabs back with a screwdriver to make the ashtrey stay put. once you remove the metal holder its obvious what the fix is.
  5. Twisted_Metal
    28,274
    1,675
    Install a V6 in your car.... It won't slide out when you accelerate. ;)
  6. hutchenc
    345
    Aug 21, 2007
    Wyoming/Colorado
    ^ Nice ^ The damn thing is so loose, it slides out just driving on a bumpy road.
    Thanks for the help guys!
  7. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,104
    38
    Sep 22, 2007
    Blind Bay, B.C.
    ;) It means don't throw your butts out the window. Another GM saftey feature.;)
  8. twozs
    twozs Veteran Member
    8,817
    169
    Aug 5, 1999
    hopewell jct ny
    the second gen camaro had one of the biggest ashtray ive ever seen ( volume wise ) . i guess that gm did the research and found the mullet crowd smoked alot. the placement is the worst though , with the 73 and up having the only ashtray in the car up by the drivers knee. that thing has got to hold about 40 butts easy . i don't smoke but back in the day (78 or so) when my friend had a 73 RS , his used to be full all the time ( nasty) . my car when i got it was a little tight so i lithium greased the track .
  9. THOMAS81Z
    THOMAS81Z Veteran Member
    3,172
    Sep 30, 2000
    new market NH
    2sided velcro tape
  10. THOMAS81Z
    3,172
    Sep 30, 2000
    new market NH
    that my good man is a shift indicator device when u bang second , if u did it correctly the ashtray slides out to hit u in the knee instantly giving u the knowlege its the rite RPM SHIFT :p :p
