Date codes on voltage regulators
Discussion in 'Original Drivetrain Topic' started by GREGS396, Jul 1, 2020.
  1. GREGS396
    GREGS396 Veteran Member
    2,446
    25
    Oct 16, 1999
    allentown pa
    I recently acquired several Delco Remy voltage regulators, and I'm in the process of looking them up for the correct applications. I have been told that the value of them widely depends on the date code. I have one for a Pontiac that's dated 08D. I assume that the 8 is the year since nothing else has a number. Another part of the puzzle is if it's 68 or 78 for the year.
    KingofThings likes this.
  2. 70lt1z28
    3,953
    871
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Probably not 78. Everything had an internal regulator by 1978
  3. BillyDean7173
    BillyDean7173 Veteran Member
    2,411
    770
    May 21, 2014
    Hutto, TX
    My 73Z has the internal regulator in the alternator and it's factory correct. Rebuilt by McCune on here and restored perfectly.
    KingofThings and McCune like this.
  4. 70 SS/L78
    2,842
    126
    May 5, 2005
    Rockford, MN
    Greg, yes you are correct. 08D is April 1968
    Far as I know many GM cars used the same regulator the year built. So that 08D could be used on more than one model of GM car for 1968.
  5. Jim Streib
    404
    67
    Apr 6, 2004
    Saint Louis, MO USA
    This is a backup for my 68 Chevy II Nova and the code of 8F denotes 1968 June.
    Maybe Pontiac and other divisions added to things like on yours being a 08D for Pontiac models but then was stamped 8D for the Chevrolet line ?
    Mine also has other numbers.
    I know finding some date code information for Chevrolet's can be tough and I can only imagine what might or might not be out there for the other divisions.
    Jim
  6. COPO
    19,625
    1,707
    The date code would be 2nd on the list. First if you were looking for a 515 then that’s #1.
  7. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    783
    45
    Aug 18, 2011
    Upstate New York
    Norwood 07C
      File size:
      79.3 KB
      34
  8. GREGS396
    2,446
    25
    Oct 16, 1999
    allentown pa
    This is one of them, and someone did write 67 Pontiac on the box. I got a few box lots from a garage that closed up. This is the only one in a GM box, the rest are the Delco Remy. 20200705_192213.jpg 20200705_192152.jpg
  9. GREGS396
    2,446
    25
    Oct 16, 1999
    allentown pa
    I just looked at a few others, and they are the 525 dated 8C.
  10. KingofThings
    KingofThings Veteran Member
    154
    38
    May 8, 2020
    Hi Jim! I have the same car and I'll check mine shortly since the front is off except for the radiator support.
    I'd like to see your car, please.
