DB Z28 The Make over
Discussion in 'Project Progress' started by DB Z28, Jun 25, 2016.
  1. DB Z28
    DB Z28 Veteran Member
    615
    73
    Nov 30, 2003
    Fond Du Lac
    Did some more work tonight. Made the sway bar end links parts. Made the parts on the lathe and threaded them to work . Had to adapt Global West lower control arms mounts to work with my Herb Adams sway bar.
  2. Tpichevy
    Tpichevy Veteran Member
    512
    16
    Jun 21, 2016
    Boise id
    How's this project going?
  3. DB Z28
    615
    73
    Nov 30, 2003
    Fond Du Lac
    Back on the car again Got laid off now I have some time to work on it again So here we go I put in a drive shaft loop in the car. It was bolted to the Transmission mount by two bolts sold by a couple of venders was made by ram air So I installed it and it was just ok was like a spring board it could flex like a 3/4 of a inch so I improved it. I added to more mounts so it would also bolt up to the rear of the transmission also. I had to trim the rear trans mount on the sides that was not being used and welded two pieces of steel to the side of the driveshaft loop bracket. and drilled two holes and installed made it a lot stronger see pictures. This is on a TKO 600 Trans[​IMG][​IMG][​IMG][​IMG]
    dave@ztech likes this.
  4. DB Z28
    615
    73
    Nov 30, 2003
    Fond Du Lac
    Got the Exhaust on today Got it to Fit really good. The exhaust was made by stainless works it 3 in with a x pipe.[​IMG]
    75Maro, Bandit723, dave@ztech and 2 others like this.
  5. John Wright
    14,998
    319
    Aug 9, 2002
    Rustburg, Va
    D/S loop looks great! Should work well in the case that the D/S wants to leave.
  6. BillyDean7173
    BillyDean7173 Veteran Member
    2,343
    743
    May 21, 2014
    Hutto, TX
    That's where I got the custom headers for my 73Z. Great quality.
  7. DB Z28
    615
    73
    Nov 30, 2003
    Fond Du Lac
    Brakes done today had a few leaks but good now. Hydro Boost installed and lines all on . Ran them along the top of the frame rail.Installed Drivers side Anvil carbon fiber fender Working on another problem with the Carb linkage hitting the air cleaner base so I modified the base Hopefully it will work with my air cleaner set up. Next is to fit the Radiator top filler panel from Anvil and the installing the Dry sump by the battery location next to the radiator. Here is some pictures
    Bandit723 and BillyDean7173 like this.
  8. dave@ztech
    4,412
    981
    Mar 27, 2016
    NY
    Hard to tell from the pictures, are your lines running in the area that the control arms are located? there will be movement there so could be issue and the control arm looks be be loose
  9. DB Z28
    615
    73
    Nov 30, 2003
    Fond Du Lac
    The control arms are loose for now. going to put a few shims to get close before it goes to the aliment shop . The lines are running below the control arms they lay on the frame about 3/8 of a inch from the control arms. so all is good their.
  10. DB Z28
    615
    73
    Nov 30, 2003
    Fond Du Lac
    Installed the Anvil close out panel today it was not a bolt in what a pain in the ass but i got it . Might have to buy different Corner braces mine don,t fit unless I trim the Panel. The top Radiator cover is just a hydro dipped to look like carbon weave The parts are loose for now . Mock up[​IMG][​IMG][​IMG]
