Dealership - ever forget to add oil in an oil change?
Discussion in 'The BS Topic' started by ErikNORCAL, Apr 20, 2015.
  1. ErikNORCAL
    ErikNORCAL Veteran Member
    1,173
    14
    Aug 6, 2003
    now in VA
    For folks that either work at a dealership or have experienced this from a dealership, is it plausible that the tech forgets to put the oil in during an oil change? Took my car in for first oil change (and car wash) and can not get a reading on the dipstick. Have checked hot and cold. Checked when new and it read on the dipstick. It's not because it's so clean either, pretty dry and sounds empty when seating the dipstick back in (tinny sound). I seriously hope this isn't the case but just in case, what can I expect? The service manager is just going to top it off from the discussion since the car is running. I've asked if they have inventory control or cameras to just check to see if the adding oil part was missed. 2014 mazda 5 2.5L manual Trans.
  2. Mike N
    2,995
    718
    Jan 13, 2002
    Spencerport, NY.
    Wouldn't be the first time some quick lane lube boob was too busy playing with his cell phone to add the proper amount of oil to an engine. Heck we've got guys where I work that dump 4 1/2 quarts in everything, shut the hood and ship it.
    I would have the car towed back and I'd want to be there when they pull the drain plug to see how much oil comes out. Collect it in jugs to see what was there versus what should be there.
  3. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    Oil pressure reading or anything? How far did you drive it before checking the oil?
  4. TL73Z28
    TL73Z28 Veteran Member
    133
    May 19, 2010
    Long Island
    This is why I do my own oil changes
  5. Gary S
    23,931
    1,516
    I change my own oil because I don't trust anybody else to do it right. Doing it my way, if the oil isn't in there, it is my fault and nobody else's.
    Years ago I had a dealer's shop mess up the car when changing oil. They got the oil change right, but messed up the air cleaner so the car wouldn't run. I don't trust them to touch the car again.
  6. BLUE72CAMARO
    BLUE72CAMARO Veteran Member Lifetime Gold Member
    4,945
    307
    Mar 15, 2004
    Bunker Hill, IL
    Let them add oil and see how much they have to add to bring it up to the dipstick if its over a quart I would raise hell!
  7. ErikNORCAL
    1,173
    14
    Aug 6, 2003
    now in VA
    only fancy gauge is a tach, else idiot lights on this car. been driving lots and hard for past 6 days. Car has 5500 miles total on it... will know tomorrow morning if I basically paid them to ruin a new car.
    Since it isn't reading on the dipstick, Think I'm going to ask them to drain vice fill to determine how much is in there. My big concern is they don't accept any responsibility since the car is and has been running though the smidge that I'm barely able to get on the very tip of the dipstick seems to have a lot of dark particles in it.
    seriously hope this is just some wacky thing with this model but doubt it.
  8. BACK IN BLACK Z
    BACK IN BLACK Z Veteran Member
    1,091
    Jul 17, 2000
    Leesville La
    Been through a similar situation.. They need to come to you and verify...DO NOT ADD ANYTHING!!! You will assume responsibility. Had our rearend break right after an "oil and lube job" . The first thing I noticed was the fact that neither plug had been removed. Work was done (signed off) at a Walmart service center. Both the tech and the store supervisor came to my house and tried to claim that the work was done. It was evident that the plugs had never been removed.. With them there, I removed the plug. There was old oil in the housing. I told the super that if I was a d!c I could easily make them pay, but I mainly wanted this guy to quit ripping them & customers off.
  9. BigBlock73
    2,173
    93
    Jul 10, 2002
    Accord,New York
    I worked at a dealer 20 years ago and one of the tech's forgot to tighten the drain plug.
    5 miles later the oil light went on.
    Women tried to drive back to the dealer and the engine seized.
    Towed in.
    The tech had to pay for the entire cost.
    It does happen,human error.
  10. red78z
    red78z Veteran Member
    2,353
    Sep 12, 2009
    pottsville,pa.
    whebn we had Lizzies dodge avenger , they forgot to put the cap back on , so it spewed oil all over everything , I called made them come tow it there give us a loaner til the engine was cleaned and an oil change w/ cap put back on was done:)
