Decode engine block 3970010 !
Shane D.
Thank you for the help and information. I'm gonna say this one has had a little work done to it then cause it's a little spunky and will spin all four 33" tires so maybe I'll start checking the numbers on the internal parts. Thank you again and sorry I had to ask but I tried searching and couldn't find the info anywhere.
bnovak
I have a 3970010 engine and trying find out what it is for sure. Front of block has vo608onn stamped in it.
Gary S
24,856
CNN code was for the L65 350 2 bbl engine so most likely it will be a 2 bolt main engine. Usually 4 bolt mains were used only on higher performance 4bbl engines.
But, you will never know until you pull the oil pan and take a look.
bnovak
Ok thanks
tom3
15,537
ohio
I have that same engine as a back up for my Camaro. It is a two bolt main with cast crank, flat top pistons. Good running motor with a set of decent heads and four barrel carb.
bnovak
Yeah this is in my 68 camaro, it has double hump heads. I'm guessing those wouldn't be original, someone probably put those on it
sandlapper
2,088
SE CSA
It's likely '68 did come OE with double camel hump heads --- as well as '69 & '70. Year '71 began low-compression era sbc with Large combustion chambers.
Pull a valve cover and find the raised Casting Number and raised Casting Date codes --- that'll usually tell the tale. Note: some have little valves, while others' valves are larger.
Blocks are similar --- in addition to pad stamp --- raised casting numbers and date codes.
JMO, the sense of 4-bolt mains' importance is exaggerated. YMMV.
bnovak
Ok thanks. I'm not sure that the motor is original none of the numbers match.
