Deformed NOS Urethane Nose
Discussion in '1978 - 1981 Specific' started by fabsj82, Mar 2, 2020.
  1. fabsj82
    fabsj82 New Member
    Mar 15, 2012
    Green Bay, WI
    Hey guys. I have this NOS nose I rescued from a guys attic. Obviously the heat has taken its toll. Is there any chance of it retaking it's original shape or am I SOL.
    Thanks
  2. 70Znut
    70Znut Veteran Member Lifetime Gold Member
    206
    124
    Feb 5, 2016
    Sarasota,FL
    I'd say your SOL, I don't think urethane has a memory without a mold.
    On the other hand, it reminds me of a Salvador Dali painting..
  3. budro6968
    budro6968 Veteran Member
    3,679
    671
    Apr 2, 2016
    Jax Florida
    Get a body shop type heat lamp and place the nose on a cradle with something to backup underside. Keep the light a good 3ft away and move the part or light around often to try and do a slow warm up. You could go close while your standing there monitoring. Don't walk away with the light close or you will come back to The Dali effect. A heat gun could help but you can damage the surface quick if heated too hot. Get a bucket of water and a rag. Soak the rag ring it a little. Push out the low spots while heating. If the part is moving easy, push it up a little higher than it would be normally and wipe it with the soaked rag. See if it will hold it's shape. This is a little tedious but you can get it back in shape with some patience.
    Canadian Barton likes this.
  4. MoarThrottle
    MoarThrottle Veteran Member
    186
    14
    Aug 22, 2013
    Denver, CO
    that looks like a long road to travel. I'd be curious if you could get it to reshape itself. Maybe a hot room with some direct'ish heat pointed at it while hanging to some sort of mold?
  5. Twisted_Metal
    27,660
    1,288
    That's just the cover.
    There's an internal support for these pieces which gives it its shape.
    (New urethane covers are smashed down into a box for shipping and look like they will never fit right when the are unpackaged.)
    I would pull that one over the support and warm it up to see how it turns out before I rejected it.
    It looks bad now but you may be surprised (hopefully) after stuffing the support piece into it.
    Good Luck!
    AK99, MoarThrottle and carr911 like this.
  6. flht99b
    flht99b Veteran Member Gold Member
    567
    163
    Nov 28, 2014
    Knoxville, TN
    Garage wall art. Make up a story about a fire and the nose is the only thing that survived.
  7. 80sz
    80sz Veteran Member
    3,341
    480
    Feb 2, 2014
    Buffalo,n.y.
    Heat it up and give it a whirl. Worst spots looks like bottom, most critical edges look decent
