Defroster vent install
Discussion in '1970 - 1973 Specific' started by gpm6367, Sep 6, 2019.
  1. hubedobeedo
    hubedobeedo 3rd times a charm
    524
    166
    Jul 18, 2013
    Huntertown,IN
    that white sealer is like the sealer for the kick panels that's a fun area to make sure it is sealed ,probably one of the most notorious causes of rust on fbodies. i know i will not put in the carpet till i am sure the don't leak (I put in new floor once)
    gpm6367 likes this.
  2. gpm6367
    938
    80
    Feb 12, 2005
    New Joisey
    478184A3-D4E1-4B5A-88CE-A7F21D965B68.jpeg Anyone know where I can get the clip that attaches to heater box bracket for cable guide?
  3. gpm6367
    938
    80
    Feb 12, 2005
    New Joisey
    0BA6C4B7-D81E-4C2E-8C3F-FE30F1D8E918.jpeg 46C99A68-A8AA-4FCF-BC1C-719DAE8BD360.jpeg Got a clean heater box and remnants of caulking does not appear white. Not sure if I’m using that white strip caulk.
  4. 70lt1z28
    3,641
    734
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I’ve never seen the clip without the heater box. Don’t think it’s available separately
    gpm6367 likes this.
  5. gpm6367
    938
    80
    Feb 12, 2005
    New Joisey
    Believe it or not I think it’s on my cables!
  6. jbloake
    jbloake Veteran Member
    364
    86
    May 1, 2002
    Atlantic Canada
    If that’s the face plate you you are using in your 70 , you know it’s a later year ! It has ” Heater “on it instead of “Air”
    gpm6367 likes this.
  7. gpm6367
    938
    80
    Feb 12, 2005
    New Joisey
    No. Don’t tell me that 70 controller is different? I’m tired of chasing heater parts!!!!
    I’ll have to order replacement face. How do the handles come off so I can remove the plastic cover?
  8. gpm6367
    938
    80
    Feb 12, 2005
    New Joisey
    65AAC9D1-69A9-4889-87FA-FD9850A5CE22.jpeg Everything clean...have to figure out to what extent I’m going to restore the heater box on firewall so as to not have it stand out. Need to maintain some patina...
  9. xten
    xten Veteran Member
    3,364
    2,145
    Sep 24, 2014
    Pittsburgh, Pa.
    Hope you had enough shop rags to clean them babies up! HaHa
    gpm6367 likes this.
  10. gpm6367
    938
    80
    Feb 12, 2005
    New Joisey
    With Rags to spare!
