Degreeing a Cam
Discussion in 'High Performance Modifications' started by Scaleytail, Sep 20, 2020.
  1. Scaleytail
    Scaleytail Veteran Member
    146
    28
    Jun 12, 2016
    North Aurora, il
    Recently changed out Camshaft. Did not degree the Camshaft, put everything back together exactly as it came off. No vacuum idle timing is at 4 BTDC and fully advanced 36 degrees is an inch away from the timing tab. The balancer is keyed, so TDC is true. It’s running pretty good, but I can’t wrap my head around the timing marks being off. Any thoughts?
  2. 70lt1z28
    3,913
    863
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Original stock damper? If so, that 40+ year old rubber can take a set and the outer ring slip. Take the damper off and compare the timing mark with a new one and see if it lines up.
  3. Scaleytail
    146
    28
    Jun 12, 2016
    North Aurora, il
    It’s a three year old engine. The balancer is keyed, soI don’t think that’s off.Lined every thing up. Just can’t wrap my head around my timing set up seems to be 8 degrees off. It runs very well ...but this isn’t right or I’m missing something.
  4. 1980RS
    1980RS Veteran Member
    4,599
    1,303
    Jun 17, 2006
    MN
    No vacuum or low vacuum may be a result of the cam. What did you have for a cam and what did you go too?
  5. Scaleytail
    146
    28
    Jun 12, 2016
    North Aurora, il
    Went from 221/226 @50 .528/.536 110 to .234/.234@50 .576/.576 111. Best vacuum is now a lil over 11.
  6. COPO
    19,475
    1,592
    Truly find your marks.
    JWhalen, Scaleytail and jthomas like this.
  7. biker
    biker Veteran Member
    2,177
    798
    Dec 7, 2014
    I think he meant he checked the timing with no vac advance hooked up.
  8. Lowend
    15,673
    839
    Mar 25, 1999
    San Jose, CA, USA
    Are you sure the wires are right on the distributor cap. I've seen a lot of very experienced techs swap wires and get some odd results
  9. Scaleytail
    146
    28
    Jun 12, 2016
    North Aurora, il
    Timing is done with the vacuum advance removed and hose plugged.Will recheck wires but the car runs pretty good. Gonna verify TDC tomorrow. Something fishy is gonna on...my timing indicates 4 BTDC-max advance is 46 thinking its actually 14 BTDC and max timing of 36 ....missing 10 degrees
  10. biker
    2,177
    798
    Dec 7, 2014
    That is odd. Reading 10 too low at idle and 10 too high at max total timing? Timing light messed up? Dial back digital on a weird setting?
    I agree that your actual timing must close to perfect. My cam is similar, and will not idle at 4" btdc
