Desk/scratches
Discussion in 'The BS Topic' started by bfmgoalie, Jun 25, 2020.
  1. bfmgoalie
    bfmgoalie Veteran Member
    2,384
    761
    Jun 14, 2008
    Gansevoort, New York
    I have a pretty expensive executive desk. I have one nasty (pardon the pun) habit - I put my feet on it while I wear sneaks. I leave very minute scratches on it. What would be the best way to remove them?
  2. Fbird
    4,922
    1,105
    Feb 12, 2011
    atlanta, ga
    i would assume it is wood?
    and has a urethane coating?
    if so....you can actually BUFF it out.....
    no coating....sand them out....then add urethane coating.
  3. bfmgoalie
    2,384
    761
    Jun 14, 2008
    It is wood and it does have a coating. What would I use to buff it out? My sis lives in Flowery Branch....how about if I ship it down there and you swing over and take care of it? :D:D:D:D:D
  4. z2880
    z2880 Veteran Member
    1,355
    63
    Jan 3, 2002
    Tewksbury, ma, usa
    Beeswax
    Buff it in
  5. Gary S
    23,435
    1,291
    Be careful. Most desktops made of real wood will be either woodcore plywood or worse, particle board with a very thin veneer of nice hardwood. Either way, it is easy to sand thruogh the thin veneer and mess it up. I would try a good polishing first with a wax. If that doesn't cover it up, then some sanding is likely the next step. Work carefully with fine grit sandpaper sanding evenly across the entire top so it matches up in the end. Once you have the scratches gone, get some good oil based urethane and recoat. I find that usually 3 coats are needed on a desktop for good coverage and durability.
  6. xten
    xten Veteran Member
    3,755
    2,566
    Sep 24, 2014
    Pittsburgh, Pa.
    There are tinted waxes for scratches. I have both light and dark at the house, but never used them. Scratched the mantle putting the big screen on it years ago, but never did anything about it.
