Agree with Twisted Metal, upgrade the posi-unit and the axles, splines must match and replacement aftermarket axles should be available from Strange and other manufacturers, and were reasonable the last time I checked. I considered doing that with the 10-Bolt in the '73, then ended up buying a Strange 12-Bolt Crate assemblyYou can use the same axles but the differential needs to have the same spline count.
You can upgrade to 30 spline axles (from 28) when you do the swap.
Check for axle wear on the ends where they ride on the bearings.
If there's any wear... get new axles.
Do it once... Do it right.
Not sure of your location but I have 2 stock limited slip units that I pulled for my build which has taken a different direction and no longer needed. Both units that I have are 28 spline, casting numbers 410408N. Please inbox me if your interested, they’re just sitting on the shelf. Hopefully someone can use them.Working on my 1980 Z28 . Was wondering if I swap out the open diff with a posi unit it's a 8 and 1/2 in rear end do I need to change axles or can I use the same axles.
Where are you located and what would you want for one of them?
Hi Arctic I responded to your inbox, didn’t want to operate outside of forum rule’s.Where are you located and what would you want for one of them?
