different width rear ends in 73
Discussion in 'Transmission & Driveline Topics' started by Ruthead, Sep 8, 2021.
  1. BonzoHansen
    20,833
    1,848
    Jun 1, 2005
    Scott from Hamilton, NJ
    i would not spend $10 on an 8.2. No, 8.5 parts will interchange.
    If it is a posi, sell it to a 1st gen guy.
  2. Ruthead
    Ruthead Member
    81
    11
    Dec 10, 2020
    Yep It sure wasn't what the guy said it was that's for sure. Prolly still laughing at me.
  3. big gear head
    big gear head Veteran Member
    6,443
    185
    Jul 30, 2001
    Ky.
    No, 8.2 and 8.5 are not the same. All first gen 10 bolt rear ends are 8.2. All second gen 10 bolt rear ends are 8.5 except for '70.
  4. Ruthead
    Ruthead Member
    81
    11
    Dec 10, 2020
    Mech took cover off and confirmed it is a posi.
    So, with the info confirmed by mech on posi and #'s on housing and 8.2 not interchangeable with 8.5 sounds like I'm done on this deal. I got no use for it. Is it worth anything?
  5. BonzoHansen
    20,833
    1,848
    Jun 1, 2005
    Its a posi, so some 1st gen or nova guy might buy it. I dunno, $200? Hopefully it has decent gears in it. Or tell the jerkoff you bought it from to take it back. lol
    Luckily used 2nd gens rears aren't typically too much. Or if you mechanic is any good you could just put new parts in your current rear.
  6. black_aerocoupe
    552
    29
    Jun 3, 2008
    McD's @ the Pavillions, AZ
    If memory serves, the 8.2 pinion nut is differently sized than the 8.5 pinion nut.
  7. tom3
    tom3 Veteran Member
    13,687
    1,220
    Aug 1, 1999
    ohio
    Could be an 8.2 posi for a 70 Camaro might actually have some value to a restorer?
  8. big gear head
    6,443
    185
    Jul 30, 2001
    Ky.
    The 8.2 pinion nut uses a 1 1/8 inch socket. The 8.5 pinion nut uses a 1 1/4 inch socket.
  9. BonzoHansen
    20,833
    1,848
    Jun 1, 2005
    But the widths would be the same if that was the case.
    big gear head likes this.
