Differential Tooling required?
Discussion in 'Transmission & Driveline Topics' started by 81LM1, Dec 31, 2020.
  1. Cardinal
    8,329
    58
    Jun 22, 2003
    Endicott, NY
    IMHO, thee best tool you can have is to a friend who rebuilds rear ends. They are usually stock car (left turn) mechanics so ask arpund your local stock car tracks for that person.
  2. camaro71/holland
    1,494
    196
    Aug 27, 2003
    The Netherlands
    Not sure I'm following you.... needed to be shimmed where? It's supposed to just rest with the collar against the housing. Where was the shim supposed to go?
  3. big gear head
    big gear head Veteran Member
    6,419
    181
    Jul 30, 2001
    Ky.
    Some of the replacement pinion seals for the car 12 bolt don't fit correctly. If you drive them in all the way they will contact the outer pinion bearing and cause problems. The seal that is currently being sold for the car 12 bolt is actually a seal for the truck 12 bolt and not all of them work well. I check them as I'm driving them in and if I see that it's going to contact the outer bearing then I will leave it sticking out 1/16 to 1/8 inch.
  4. camaro71/holland
    1,494
    196
    Aug 27, 2003
    The Netherlands
    Got ya, haven't run into this problem yet, but most of the time I work on 10 bolts.
  5. 67johnny
    67johnny Veteran Member
    291
    18
    Apr 14, 2016
    vancouver
    What BGH said! :crazy:
    I think I calculated 1/8th of an inch. (.125)
