Do I paint it or ?????
Discussion in 'The BS Topic' started by muscl car, Sep 6, 2020.
  1. muscl car
    22,806
    1,389
    Jul 8, 2001
    SoCal High Desert
    my Ford 9" housing , im thinking of just painting the axle tubes gloss black and leaving the center section as is . Also the 3rd member is aluminum so not painting that either
    What's your thoughts ?????
  2. DB Z28
    DB Z28 Veteran Member
    617
    75
    Nov 30, 2003
    Fond Du Lac
    Gloss Black with Clear coat aluminum center section
    70-camaro and muscl car like this.
  3. Jodi
    Jodi Veteran Member
    497
    267
    May 22, 2019
    Satin or Semi-Gloss black on the entire housing and leave the aluminum 3rd member the way it is.
    John Wright, Zstar, biker and 3 others like this.
  4. Twisted_Metal
    28,310
    1,692
    I figured this post was going to be about painting the body. :confused:
    I don’t like to leave metal bare.
    In your climate, aluminum will probably stay pretty decent looking but I would still shoot it with clear.
    The axle tubes I would definitely paint black.
    70-camaro, gramps and muscl car like this.
  5. muscl car
    22,806
    1,389
    Jul 8, 2001
    SoCal High Desert
    I do like the look of satin black and the natural look of aluminum !!!!!!
    Zstar and Jodi like this.
  6. muscl car
    22,806
    1,389
    Jul 8, 2001
    SoCal High Desert
    I've seen quite a few aluminum intakes that the clear coat turns yellow
    Zstar likes this.
  7. Phil G
    Phil G Veteran Member
    824
    81
    May 3, 2004
    Tucker, GA, USA
    I'd consider painting the axle tubes black and then polishing and clearcoating the aluminum parts. Probably with less heat the clear will stay good. Either that or polish the aluminum parts then crawl under with a can of NevrDull for the occasional touchup. I have non-coated American Racing Aluminum wheels on my Monza and that stuff makes them sparkle! Learned about NevrDull from a truck driver (owner operator) that delivered and picked up from the company I worked for. He would dig the can out and go over the rig while our guys unloaded the incoming and loaded the outgoing. Aluminum wheels on tractor and trailer plus other places. By the time our guys were done so was he!
    muscl car likes this.
  8. dave@ztech
    4,411
    981
    Mar 27, 2016
    NY
    Paint it, the guys that painted mine used Steel-it , they swear by it , for rear ends !
  9. Fbird
    4,937
    1,107
    Feb 12, 2011
    atlanta, ga
    I would not even try to rattle can something like that regardless of brand.....just going to be meh....
    If your going thru this much stuff....for a rear end!!!.....have it actually painted. Yeah YOU can do all the prep work (hard stuff) and just have the paint shop shoot it with chassis black or whatever..
    The aluminum 3rd member. Again clean, prep, let the paint shop shoot it with clear. The BEST rattle can I've ever seen ...SUCKED in 2 yrs.
    Zstar and muscl car like this.
  10. biker
    biker Veteran Member
    2,177
    798
    Dec 7, 2014
    Agreed!
    Jodi likes this.
