Does Camaro have 5x4 1/2 lug pattern?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by jayfire, Jun 28, 2009.
  1. jayfire
    jayfire Veteran Member
    585
    Jun 26, 2008
    dayton, nevada
    I found an ad on craigslist for these turbine wheels and he said that he pulled these wheels off a camaro for sure and that the lug pattern was 5 by 4.50 Is this true? Both my camaro and firebird are 5 by 4.75. Is he measuring wrong?
    http://reno.craigslist.org/pts/1243042803.html
  2. Kamikaze
    5,040
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    All Camaros have been 5 x 4.75 pattern.
  3. tom3
    tom3 Veteran Member
    13,693
    1,238
    Aug 1, 1999
    ohio
    Early Fords and Mustangs had the 4.5 I think.
  4. blades67
    blades67 Veteran Member Lifetime Gold Member
    1,542
    Oct 22, 2005
    Chandler, Arizona, USA
    Fords and Mopars use a 5X4 1/2" lug pattern. If he pulled them off a Camaro then they have a 5X4 3/4" lug pattern and he's just mistaken about the size.
  5. POS71RS
    POS71RS Moderator Staff Member Lifetime Gold Member
    10,333
    9
    Aug 21, 2002
    Central Coast, CA
    instead of measuring from center to center of the lug holes, I'll bet he measure from one side of one hole, to the wrong side of another hole.. if that makes sense...
    ie, the holes are probably 4.5 inches apart, but the center to center is 4.75...
  6. circle racer
    circle racer Veteran Member
    374
    Jul 27, 2006
    South Central Michigan AKA the Land of Salt, Rust,
    I think that the 67-69 Camaros had a 4 1/2 inch pattern.
  7. Gary S
    24,050
    1,571
    No, the 67-69 Camaro uses the same 4.75" pattern as our cars.
    The 4.5" is a Ford and Mopar thing.
    To measure correctly, you have to measure exactly across the center of the hub to know the distance from the hub. With 5 holes, you don't have any two holes exactly in line with the center of the hub. It is simple geometry. Measure right and you get the right measurement.
  8. 70rat
    70rat Veteran Member
    1,872
    Mar 23, 2003
    Reno,NV USA
    Actually it's not center to center on a 5 lug bolt pattern.
  9. POS71RS
    10,333
    9
    Aug 21, 2002
    Central Coast, CA
    ^ ^ ^ no crap... oops!
  10. F-Bodypilot
    F-Bodypilot Veteran Member
    342
    Jan 9, 2009
    Crescent Valley BC Canada
    And the winner is.......
