Does it matter where the roll bar meets the floor plate?
Discussion in 'Competition Camaros' started by djkaplan, Sep 24, 2018.
  1. djkaplan
    djkaplan Veteran Member
    162
    Mar 27, 2016
    Victoria, bc
    Im wondering if it matters where the main hoop meets the floor plate? Can it be set off to the side or dose it have to be centered?
  2. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,657
    1,075
    Mar 27, 2016
    NY
    I suppose the depends on what you are planing to weld it to , the floor pans or the frame?
  3. djkaplan
    162
    Mar 27, 2016
    Victoria, bc
    It will be welded to the floor pan
  4. dave@ztech
    4,657
    1,075
    Mar 27, 2016
    NY
    then I guess it will not matter, I thought you had to mount to something solid, so when it rolled over it wouldn't punch right through the floor, however, I might be wrong, happens alot !!! HAA HA
  5. Revin
    Revin Veteran Member
    641
    135
    Aug 31, 2016
    Round Rock , TEXAS
    You WANT it to be attached to the frame rails, NOT the floor!
    It will do no good when you roll over and the bar drives straight through the floor. It is ment to save your life.
    Still if a show bar, then you will still need to fab up a bracket to move it from the rails over to the floorboard. You do know the floors are made of thin sheet metal??:screwup::screwup:
    budro6968 and wiseryder like this.
  6. djkaplan
    162
    Mar 27, 2016
    Victoria, bc
    6x6x.125 plates welded to the floor/rocker area are upto spec on a unibody car.
    I will be placing the plates overtop the torque box and partially over the rear frame rail. Attaching it to the rail would make the bar too skinny to pass tech.
    Smokey15 likes this.
  7. John Wright
    15,290
    431
    Aug 9, 2002
    Rustburg, Va
    Yes...do plate the floor.
  8. Smokey15
    Smokey15 Veteran Member
    3,412
    1,474
    Aug 13, 2017
    Caledonia, MI
    X2. If you plan on taking the car to the track, pick up an NHRA rule book. As long as you are going through the labor, etc. to install a bar, you should do it correctly. I hope you never need it, but it could save your life.
  9. ZEN357
    ZEN357 Veteran Member
    384
    71
    Feb 12, 2018
    It's a waste of money if you weld it to a floor pan. It needs to be welded to the frame rails to do any good otherwise it's for looks only.
  10. G72Zed
    G72Zed Veteran Member
    3,485
    1,903
    Sep 8, 2015
    x2 ^ And if it's for looks only, It may actually be a negative for a "true" street car.
