Does this valvetrain geometry look ok?
Discussion in 'Engine Topic' started by fstarocka, Jan 22, 2021.
  1. G72Zed
    G72Zed Veteran Member
    2,809
    1,315
    Sep 8, 2015
    Good points by 1320feet.
    I will add, the +.100 longer valve is adding to the issue as the tip is now closer to the stud center-line.
    Also, although a great video on the "Mid lift theory" and attaining it's geometry, it's a BBC, your working on a SBC, with a stud mount arrangement, and this generally favors the "low pivot" option.
    Crower do make .090 backset trunion RR for this setup. I think they are not cheap at $380 for a set of 8. So get out your wallet on that one for sure.
    The last thing I buy is the push rods as you do not know what length you need until it's all assembled. And use your real springs for final checks and patterns.
    fstarocka likes this.
  2. 77 cruiser
    77 cruiser Veteran Member
    587
    36
    Nov 17, 2006
    Frostbite Falls MN
    You can try the maker method & trying different PR lengths till you find the narrowest pattern.
  3. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
    Ok i finally managed to get it done RIGHT! pattern is TINY, like 45 thou. I needed longer rocker studs and all is good! Im very happy - upgraded to 3/8 pushrods at the same time. Ill use the 5/16 parts for my milder 400hp 350 build -
  4. sandlapper
    sandlapper Veteran Member
    646
    218
    Oct 9, 2020
    SE CSA
  5. G72Zed
    2,809
    1,315
    Sep 8, 2015
    Good to hear this news that it's worked out for you in the end, .045 width pattern is nice, and the jump to the larger 3/8 diameter pushrods has no downsides other than fitment in some cases, but it's worth it.
