Don't cut your floor board for a spun cage nut
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Caveman Tiny, Aug 12, 2012.
  1. Caveman Tiny
    Caveman Tiny Veteran Member Lifetime Gold Member
    520
    Sep 4, 2011
    New Orleans, LA
    I installed PTFB solid body bushings in my 1980 Z28 this weekend. I sprayed the bolts with PB Blaster for several days before I started the project. When I started breaking the bolts loose I had 3 spun cage nuts. The first one was position 2 (under firewall) on the passenger side. On the driver side, 2 and 3 (rear of sub frame) were spun. I've read several posts where people have had to cut their floor boards to access the cage nut. I found a solution that worked on my car. For the bushings at position 2, I removed the front wheels and inner fender wells. There is a square opening that allows access to the cage nut. I used a medium size C clamp to press the cage back down. The bolt came out easily.
    Cage nut:
    The position 3 was even easier. There is an oval shaped hole outboard of the bushing in the square shaped part of the body. I could feel the cage and nut with one finger. I was able to get a small C clamp into the hole and press down on the cage nut flange. The bolt then came out easily.
    I'm not sure if this has been posted before or if the early 2nd Gen's have this same opening. I hope this helps someone out.
    Flyingkiwi likes this.
  2. wayback
    wayback Veteran Member
    1,718
    Mar 5, 2000
    Jungleland, Minnesota
    That's awesome! I don't recall seeing your solution before. Next time I'm under the car I'll take a peek at those rear access points.
    Thanks for sharing the idea!
  3. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,117
    50
    Sep 22, 2007
    Blind Bay, B.C.
    Not that I needed to do this, still is great news there is a better way. Awesome
  4. Gary S
    24,232
    1,696
    When I removed mine, I simply ground off the heads of the bolts with an angle grinder and the broken cage nuts pretty much fell out.
  5. bsievers1616
    bsievers1616 Veteran Member
    234
    Sep 20, 2010
    Plano, TX
    Cool, thanks for this trick. I'll be attempting it this weekend.
  6. Rich Schmidt
    Rich Schmidt Veteran Member
    4,285
    40
    Mar 27, 2010
    Denville NJ
    Wow,you learn something new every day. I have been building these turds for over 20 years and never thought of that. Even better yet might be to do it before you even try to loosen the nuts,it would offer even more advantage. Thanks for the trick,I hope I remember it the next time I have this problem.
  7. 77nomad
    77nomad Veteran Member
    2,123
    Nov 20, 2009
    Ski Town
    This IS the tip of the day. I read a post about once a month on other boards about spin nuts. I will now link them to this thread.
  8. Hoot
    Hoot Veteran Member
    1,475
    Jul 12, 2008
    Greenville MS
    1 1/8 wrench fits on the #2 one, at the firewall. thats how i got those loose. I did have fenders and such off though. the c clamp is a great idea though. Thanks for sharing.
  9. John Wright
    15,293
    433
    Aug 9, 2002
    Rustburg, Va
    Don't believe that I've seen this C-clamp idea posted on NastyZ before....thanks for the tip.
  10. blades67
    blades67 Veteran Member Lifetime Gold Member
    1,542
    Oct 22, 2005
    Chandler, Arizona, USA
    Awesome tip! I have to replace my bushings and I've been putting it off until I could get a MIG machine in case I had to cut the floor.
