Door and fender gaps on a 73
Discussion in 'Body Restoration' started by shaggyzr2, Mar 10, 2021.
  1. giggity
    giggity Veteran Member
    1,500
    362
    Mar 18, 2013
    Pearland, texas
    Im not. It was just up when I took the picture. I have welded in subframe connectors, so flex should be at a minimum, but still doing it on the ground
  2. Allison Winn
    Allison Winn Member
    89
    12
    Jan 10, 2021
    My bad on the .120! It was .220" ish. Memory ain't workin 20210316_204040.jpg
  3. G72Zed
    G72Zed Veteran Member
    2,701
    1,263
    Sep 8, 2015
    As been said, shoot for 3/16 to 1/4 (.187-.250) when all said and done. If it's bare metal, used some bright green masking tape on the gaps to give you a good visual for gap width consistency, and it will add the mil thickness for the paint.
    If you want to tighten things up some, I use .125 on the door/quarter, .190 door & hood to front fenders and hood to header comes in around .220/.250 or so.
    Always start with the door to quarter/rocker and then move forward.
    You should always make sure you have the door seals in place and do the paper test or grease/Vaseline to make sure you have a full contact seal with the inner door opening structure, and no binding should you get greedy moving the door shells back. Putting on new door skins allows this alignment to be tweaked a lot easier, not so much when the skins are on.
    Hope this helps you out.
  4. G72Zed
    2,701
    1,263
    Sep 8, 2015
    You will not close up those door/top of fender gaps easily, the fender tops need to be reshaped for the most part. And your right, you need a good metal/body man, the magic that they will use will include body hammers/dollies/metal file/MIG and 1/8 steel rod, then watch the magic happen.
    I have GM fenders/hood/door and I had to play magician as well, minus the 1/8 welding rod.
    giggity likes this.
  5. badazz81z28
    20,373
    1,334
    Alabama
    Yeah, perfect will take welding, shaping and filling.
  6. giggity
    1,500
    362
    Mar 18, 2013
    Pearland, texas
    Im looking for close. Car is by far going to be perfect. I want it to look good.
