door latch problem, door won't open
Discussion in 'Troubleshooting & Diagnosis' started by ericj205, Apr 2, 2011.
  1. ericj205
    ericj205 Veteran Member
    1,758
    Jun 16, 1999
    Huntsville, AL USA
    :mad: My passenger door is stuck. Both the inside and outside handles seem to be operating the latch and linkage effectively when I compare to the driver's door.
    I noticed there are two stages of the latch mechanism, the first allows the door to open about 1/2" then the final allows the door to come completely open (guess its for safety like the hood?). Well mine will open the first stage, enough so that I can reach my fingers from inside the car and feel that the second stage is still grabbing the striker bolt. My door panels are off so its easy to see and work inside but I can't get it past the second stage.
    Anyone experience this? I tried loosening the strike but no help. Any ideas?
  2. Twisted_Metal
    30,172
    2,880
    I'm serious. :eek:
    Boot it open from the inside while someone else holds the handle up and pulls from the outside.
    Make sure the lock is released first..
  3. steve_1978
    steve_1978 Veteran Member
    375
    May 5, 2010
    ontario canada
    same thing happened to mine, climbed in through the driver side pulled on the inner door handle to open door, then i booted it, opened right up for me, then i lubed it up real nice and has been workin nece ever sence
  4. hoov81
    hoov81 Veteran Member Lifetime Gold Member
    748
    27
    Oct 31, 2010
    Bristol, WI
    Boot or a shoulder works good. Sounds latch mech. is shot. Or the Latch pin on the jamb is worn out. Good luck
  5. David_56
    David_56 Veteran Member
    586
    Jan 10, 2009
    Atascadero California
    +1 for booting it
  6. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    Before footing the bill for a new latch, check the adjustment on your striker. I have had some that, if the striker is shimmed out too far,will actually drag on the latch and be very hard to open. Just a thought.
  7. Fbird
    5,878
    1,738
    Feb 12, 2011
    atlanta, ga
    welcome to the 200 lb F%^&* door issue :) You are now an actual member of the 2nd gen fbody survival team!
