Door skin time
Discussion in 'Body Restoration' started by arick793, Mar 12, 2017.
  1. 70-camaro
    70-camaro Veteran Member
    3,127
    1,332
    Mar 25, 2010
    marietta ohio
    The one I bought at a local auto paint store is rated for 1000 lbs. If I remember right the stand was $50.00, the wheels were 20.00 or 25.00.
  2. Shizzle
    Shizzle Veteran Member
    2,751
    743
    Aug 1, 2012
    oak lawn, illinois
    Actually they support the doors just fine. They aren't flimsy either. I'd bet my stands & your stands are made in the same Ching-Chong factory.
    budro6968 likes this.
  3. RickM
    RickM Veteran Member
    558
    88
    Apr 16, 2004
    Gaithersburg, MD
    I did a door skin on my 81. Never done any body work but watched a guy do a skin on youtube. I needed to weld new metal on mine since the bottom of the door was rusted. I also bought a door skin hammer from harbor freight. It really made the job easier. Take your time lining everything up. When folding the skin on take your time and do a little at a time. I probably went around the door 15 times before it was completely folded over. I also applied SEM seam sealer between the skin and the door frame. I also sprayed rubberized undercoating on the inside of the skin before I installed it. Don't forget to put healthy blobs of sealer between the door crash bar and the new skin. On the drivers side you will need to transfer the mirror mounting bracket from the old door to the new (welding required). You also need to weld the door skin to the door frame at the top of the door.
    It took me a long time to do it. But it can be done if you take your time.
  4. arick793
    arick793 Veteran Member
    1,127
    Oct 27, 2008
    Rochester, NY
    I have time. I have extra doors! Great tips, thank you.
  5. arick793
    1,127
    Oct 27, 2008
    Rochester, NY
    Today I bought the stand and the door skin hammer from Harbor Freight. I'll let you guys know how they work out
  6. cadillac_al
    cadillac_al Veteran Member
    927
    112
    Apr 22, 2015
    Maine
    My body man bud always test fits the door with the new skin before all the final crimping. He claims the hassle of mounting the door is much easier than spending 2 days getting the body gaps aligned to the door. I thought about skinning mine for a long time but ended up finding another door. Good luck.
  7. budro6968
    budro6968 Veteran Member
    3,755
    694
    Apr 2, 2016
    Jax Florida
    Show us a pic of the hammer Please. I have the hammer & dolly set from H/F, Kind of crappy. The stand too. The stand is great not flimsy.
  8. arick793
    1,127
    Oct 27, 2008
    Rochester, NY
  9. budro6968
    3,755
    694
    Apr 2, 2016
    Jax Florida
    Thanks for the pic. I just found it on the H/F web site, Item #63263 for 24.99. Not a bad price. Probably only use a couple times.
  10. 80sz
    80sz Veteran Member
    3,649
    580
    Feb 2, 2014
    Buffalo,n.y.
    My tip is hang door on car before you tack in the skin. My previous painter didn't and it was hard to adjust fender gap. The door is easy to shim back ,up,or down but moving forward to close fender gap is a pain. I will most likely have to pull off and redo or add and remove metal to get it correct.
    clay's70 likes this.
